im not sure if its coil whine or whatever it is.. its a weird sound that only occurs when i start graphic intense games. i started unigine valley and i instantly heard it, same in bf1. my card is a Gigabyte GeForce GTX1080 Windforce OC.. what should i do?
Watches and computers
https://linustechtips.com/topic/700425-coil-whine/
sure it's not the PSU ? If it's the GPU, nothing you can do, I had a pair of 970's that were terrible, got lucky with my 1080
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/700425-coil-whine/#findComment-8956708
When you turn up the volume in the OS, it is raising the sound levels going to your speakers. Since there is more interference inside your computer than outside, the increased sound levels from the OS will come with more noise.    Keeping the sound levels low in the OS should minimize that noise.  I have had experience with this with my 7850.
https://linustechtips.com/topic/700425-coil-whine/#findComment-8956781
i cant really turn up the volume on just my headset. i activated v-sync and the card got a lot quieter..
https://linustechtips.com/topic/700425-coil-whine/#findComment-8956813
