hard drive wipe
Go to solution Solved by SirYanthon,
3:35-4:11
fantastic!! :D
so i had a windows 8.1 computer that got the free upgrade to windows 10, and i want to sell it to someone else; but i want to truely wipe all the data off it so other cant get my info. my options then are to either use a flash drive to manually reinstall it, and reformat the drive, but then idk if it would give me an unlicenced version, sonce the pc didnt come with a licence key when i came with windows 8.1, or i can use the built in windows 10 option to wipe the harddrive and reinstall, but what i wanna know is does it actually get rid of all my files? or does it just delete them?
https://linustechtips.com/topic/700058-hard-drive-wipe/
just run http://www.dban.org
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
https://linustechtips.com/topic/700058-hard-drive-wipe/#findComment-8952750
3 minutes ago, EdgieHippie said:
whats that?
see edit
https://linustechtips.com/topic/700058-hard-drive-wipe/#findComment-8952776
2 minutes ago, KOMTechAndGaming said:
see edit
im assuming that would run off a usb drive tho, and that would then require me to reinstall windows 10 off a usb as well, and id have an unlicenced version, which id rather not since i did pay for that windows 8.1 licence. i just dont have a key. is there perhaps some way of finding that key?
https://linustechtips.com/topic/700058-hard-drive-wipe/#findComment-8952787
not sure to be honest
https://linustechtips.com/topic/700058-hard-drive-wipe/#findComment-8952798
https://support.microsoft.com/en-us/help/12440/windows-10-activation
under: Activating after reinstalling Windows 10
it says: If you activated a free upgrade to Windows 10 or bought and activated Windows 10 from the Windows Store, you have a digital license for your device. This means you can reinstall the same edition of Windows 10 that your device has a digital license for without entering a product key. During reinstallation, if you’re asked to enter a product key, you can skip this step. Windows 10 will automatically activate online after the installation is complete
im guessing that wouldnt work if i truely wiped the drive tho cause then that key wouldnt be there
https://linustechtips.com/topic/700058-hard-drive-wipe/#findComment-8952834
It would be there. It's not stored on the HDD but online. Microsoft's server will recognize the device by mobo serial number.
https://linustechtips.com/topic/700058-hard-drive-wipe/#findComment-8952850
do you perhaps have a source page on microsofts site confirming this?
Nope, I just know it. You can search microsoft's website if you don't belive me, it's gotta be there somewhere. Also I'm pretty sure Linus mentioned this in one of his videos.
https://linustechtips.com/topic/700058-hard-drive-wipe/#findComment-8952879
Just now, Verrierr said:
I suppose you could go with either removing everyting or restoring factory settigns. Windows will not ask you to re-enter license key if you do.
well yea, but idk if it would truely get rid of all my files and make them unrecoverable, or if they would simply be deleted
https://linustechtips.com/topic/700058-hard-drive-wipe/#findComment-8952898
They'd be recoverable given someone was willing make some effort. If you want to be 100% sure your future buyer won't be able to access any of your stuff, you'd have to use software to wipe your drives clean.
Edit: For stuff like this I use MiniTool Partition Wizard (free version is enough) and I think it's worth recommending
https://linustechtips.com/topic/700058-hard-drive-wipe/#findComment-8952904
