5 minutes ago, DES7OY3R said:
Still doesn't work wifi is like connected to a router and some circles are flashing
Have you tried accessing the internet from another device connected to the same network? Also, have you tried shutting down the phone and powering it back up? Spinning circle flashing in the status bar usually indicates something trying to connect and retrieve data.
I did try restarting the phone and the wifi keeps flashing on and off
