Desk LED choices.
Holmes2468
I didn't know where to post this topic exactly but I'm going to guess here would be just as good.
I'm planning to a LED light strip to my desk, TV, and TV stand. I was wondering if anyone used the Sylvania RGBW LED Strip. I know there are cheaper options out there, but I'm a little skeptical due to the cheaper units having performance and/or sticking to surfaces issues.
https://www.amazon.com/gp/product/B008COVFUA/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
I know I would at least need two of these starter packs with an expansion pack for the TV stand.
My other option is to save and go after the Phillips HUE LED strips since I already own the Phillips Hue Starter kit.
http://www.bestbuy.com/site/philips-hue-lightstrip-plus-6-6-multicolor/4373913.p?skuId=4373913
IKEA?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
1 minute ago, ARikozuM said:
IKEA?
No such place. Just like Macy's
This is the kit that I use. It survived a move to southern California from Pennsylvania so it holds up pretty well.
I'll post pictures of what they look like set up if you want.
https://www.amazon.com/SUPERNIGHT-Changing-Flexible-Remote-Control/dp/B00BP4DUMU/ref=sr_1_14?ie=UTF8&qid=1480480551&sr=8-14&keywords=led+strip
EDIT*
My bad, this one.
https://www.amazon.com/SUPERNIGHT-Waterproof-300LEDs-Flexible-Controller/dp/B00B2F3KDQ/ref=pd_sim_60_7?_encoding=UTF8&pd_rd_i=B00B2F3KDQ&pd_rd_r=9VGD3933MCDT2QEMW5RR&pd_rd_w=mmGIv&pd_rd_wg=gyfOi&psc=1&refRID=9VGD3933MCDT2QEMW5RR
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
No IKEA? Where do you live? I'll add it to my "Places to Never Live" list.
You can probably get by with any LED from a reputable mark (not brand name, but known maker). Sylvania looks to be a good choice.
Omaha, NE
4 minutes ago, Brink2Three said:
If I cut the LED, it there a way to salvage the left over? I only need 46" for my desk a lone, 144" for my TV and 72" for my TV Stand
Yep, Just make sure you cut on the solder joints. I did this with my desk as well.
Stille (Desktop)
Evoo Gaming 15"
Looks fine, but no remote and you can't cut those. :/
Stille (Desktop)
Evoo Gaming 15"
I was looking at the Sylvania because of the RGBW. The W is a 4th pure white LED.
The Hue interested me because of the fact I have the Hue hub and ai can control it all from my smart phone
I use these for my desk:
https://www.amazon.com/gp/product/B01DBINHWA/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
They look great and have held up well for me so far. Unfortunately there isnt a pure white LED. You can get some more wire and connectors to use the extra strip.
More wire: https://www.amazon.com/gp/product/B00DPQMKBS/ref=oh_aui_detailpage_o01_s01?ie=UTF8&psc=1
connectors: https://www.amazon.com/gp/product/B00SVE8C16/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
I was looking at the NZXT Hue+ too. if I installed in in my case, I was debating on getting extention cables and RGB my desk on channel 2.
