Help me decide
Go to solution Solved by Swordtiny,
get the LG 29UM67P
Ok so just finishing up my build and thinking of buying a monitor just cant decide don't want to spend too much but want a good 1080p or better gaming monitor. Trying to keep my budget on this around between $100-$220.. Don't have much longer on these deals and not sure if anyone is awake to help...
Here is my current build https://pcpartpicker.com/list/wfw6pb
Here are 3 monitors I am currently looking at
http://www.newegg.com/Product/Productcompare.aspx?CompareItemList=-1|24-025-112^24-025-112%2C24-236-584^24-236-584%2C24-025-212^24-025-212
http://www.newegg.com/Product/Product.aspx?Item=N82E16824025112
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236584
http://www.newegg.com/Product/Product.aspx?Item=N82E16824025212
Edited by dj_duddles
https://linustechtips.com/topic/699097-help-me-decide/
