hi all wondered if anyone can help me
my fans in pc are starting to become really loud so decided to replace them as my local store has offers on noctua fans so which ones will be the best for purpose
cpu cooler = 120mm
case fans = 120 / 140 mm
I know some noctuas are built for a specific job so which ones would be the right choice as I don't understand how airflow, pressure and static pressure works
thanks
https://linustechtips.com/topic/69894-noctua-fans/
Anything that has to push air through, use a nf-f12, anything for just airflow (nothing blocking it) use nf-s12a pwm
https://linustechtips.com/topic/69894-noctua-fans/#findComment-957496
(NF-P14? Someone check me...)
or the NF-A14 FLX
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/69894-noctua-fans/#findComment-957517
