Medium build help
Solved by 3 Lions,
Don't upgrade to another AMD CPU, go for Intel however you will need a new motherboard and new RAM as the current (Skylake) and new (Kaby Lake) only support DDR4. Keep your current GPU for a bit longer so you can save up more money for a GTX 1060 6GB.
kasdashd ·
1
6
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
