Hello friends, I have a problem here with my game. I can run paladins at max settings without any problems but recently I only get like 24fps on average and random chunky lag spikes on that game. I can run rise of the tomb raider which is obviously more demanding then paladins at 30-40fps but I my pc can't manage paladins quite well. Any solves for that problem? Is that just the game sucks? Or is it some thing wrong with my hardware?
Here is my pc specs if that matters
Proccesor: Intel Pentium G4400 @ 3.30GHz
Graphics Card: Zotac GTX1050 Mini (not overclocked)
Ram: Adata 8gb 2133MHz DDR4 memory
Motherboard: Asus H110M-K
Storage: Western Digital 1TB Caviar Blue
https://linustechtips.com/topic/697810-problems-with-my-frames-need-help-asap/
My guess is that there are occasional points in the game where there is a lot for your GPU or CPU to handle. Monitor your GPU and CPU usage while you play the game and see if there is any correlation to anything. Look for particles, NPCs or anything else that could push your GPU/CPU
Use MSI afterburner and use their OnScreenDisplay to monitor your CPU/GPU usage. My guess if you can't run Paladins well is your CPU is too weak.
Personal build >  New-ish AMD main gaming setup
   PLEASE QUOTE OR @ ME FOR A RESPONSE xD
yeah i have fps monitoring thing on and i still get lag spikes and 30 fps when i turn down the settings
2 minutes ago, zc0201 said:
Yeah cpu usage was at 100%
if your CPU usage is at 100% while your GPU is at 60-70% or less then theres a clear CPU bottleneck.
but before the ob38 update it was doing just fine and i reckon a pentium g4400 won't bottleneck with an entry level gtx1050?
I reckon a pentium g4400 won't bottleneck with an entry level gtx1050?
Usually no, but its not a set requirement. it varies from game to game.
Start writing your email to the Devs.
