So I currently am planning on using the Corsair Carbide 100r case with the following build
https://pcpartpicker.com/list/h69kgL
However, I would like a case with a bit more room for cable management behind the mobo. I really like the side panel however, and so I would like to keep that if I can. I don't need a case with a lot of fans, but preferably just one in the back like the 100r.
(Btw if you already haven't caught on I'm not planning on getting the silent edition)
Any help is appreciated
Thanks
Edit: It would be great if it is black, too.
Welcome to Maryland.
We have crabs.
https://linustechtips.com/topic/697633-need-case-selection-help/
If you can afford this, this would be a great case for the price: https://pcpartpicker.com/product/VyKhP6/phanteks-case-phec416pag
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/697633-need-case-selection-help/#findComment-8927916
Sorry to put this in the post, but I would love it if it would be black too. I will edit it. Thanks anyhow though.
We have crabs.
https://linustechtips.com/topic/697633-need-case-selection-help/#findComment-8927923
