How Good Is ThermalTake C1000 Coolant And Does It Have Anti Microbial Properties?
Solved by 0ld_Chicken,
1 hour ago, ArcticWolf_11 said:ah, I bought a 480mm Alphacool NexXxoS Monsta Radiator so I think i'm good there. But I did buy their pump and reservoir combo sooo hopefully that's good. I'm also using a thermaltake core p5 case.
That should be alright. I haven't heard anything drastically wrong with their pump/res, just not a great design.
A case is a case so it shouldn't give you many issues. I had a P45 and I rather liked it
