8 minutes ago, TurkeyClub said:
Hey guys, Im planning a build in a Micro ATX corsair air 240, and wanted to know what you guys thought of the hardware.  I already have a moniter, and I want the whole build under 850$.  Thanks for any recommendations!
PCPartPicker part list: https://pcpartpicker.com/list/bYTLwV
Price breakdown by merchant: https://pcpartpicker.com/list/bYTLwV/by_merchant/
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($219.99 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($19.88 @ OutletPC)
Motherboard: ASRock Z170M Extreme4 Micro ATX LGA1151 Motherboard  ($74.99 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($74.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.89 @ OutletPC)
Video Card: Asus GeForce GTX 1070 8GB Dual Series Video Card  ($359.99 @ Newegg)
Case: Thermaltake Core V21 MicroATX Mini Tower Case  ($34.99 @ Newegg)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($29.99 @ Newegg)
Keyboard: Thermaltake Commander Bundle Wired Gaming Keyboard w/Laser Mouse  ($28.97 @ NCIX US)
Total: $892.68
Generated by PCPartPicker 2016-11-25 21:13 EST-0500
My Current Rig:
CPU: Intel Core i5-6600K CPU Cooler: Cooler Master Hyper 212 EVO GPU: ASUS STRIX OC 1070 Motherboard: MSI Z170-A Gaming M5 Memory: Corsair Vengeance LPX 2 x 8GB DDR4-2400 Storage: A-Data Premier 240GB SSD/Seagate Barracuda 2TB 7200RPM Case: NZXT S340 PSU: Corsair RM750i Monitors: Acer R240HY/ Dell S2716DG
https://pcpartpicker.com/list/xwcjLD
https://linustechtips.com/topic/697128-first-build-advice/#findComment-8923484
go with the intel i5 6500 you dont need the unlocked version if your not doing any major 4k gaming or major editing. if you have a old pre build system take the windows from that. and one last thing i would go for the 1060 single fan its only $80 more and your getting a lot more out of it. if you want the small form factor case thats fine but if you go with a mid atx cases it would make everthing cheaper. i can help you with that if you want me to.
https://linustechtips.com/topic/697128-first-build-advice/#findComment-8923496
Mid atx definitely doesn't make it cheaper.
My Current Rig:
https://linustechtips.com/topic/697128-first-build-advice/#findComment-8923505
10 minutes ago, Percenary said:
Total: $892.68
https://linustechtips.com/topic/697128-first-build-advice/#findComment-8923537
Just now, plasticplanet said:
i5 6600k is only $190?
Microcenter
My Current Rig:
https://linustechtips.com/topic/697128-first-build-advice/#findComment-8923546
1 minute ago, Fr0sty22 said:
yes but that deal is only today and maybe monday but micro centers are only in the us and not in every state only a few. it sucks ik.....
are you from Canada?
My Current Rig:
https://linustechtips.com/topic/697128-first-build-advice/#findComment-8923560
damn just bought one from newegg today for 220 today and microcenter  has a store in my near my neighborhood, lol
https://linustechtips.com/topic/697128-first-build-advice/#findComment-8923562
if you don't mind rebates:
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($219.99 @ NCIX US) get an i5 6500+cheap h110 mobo if you don't wanna overclock/can't handle rebates.
CPU Cooler: CRYORIG M9i 48.4 CFM CPU Cooler  ($19.99 @ Newegg Marketplace)
Motherboard: ASRock Z170A-X1/3.1 ATX LGA1151 Motherboard  ($62.98 @ Newegg)
Memory: Team Elite Plus 16GB (2 x 8GB) DDR4-2400 Memory  ($64.99 @ Newegg)
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive  ($59.99 @ Best Buy)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($42.99 @ Amazon) get later if you can't handle rebates.
Video Card: XFX Radeon R9 Fury X 4GB Video Card  ($304.98 @ Newegg) same performance as the gtx 1070 but cheaper.
Case: BitFenix Comrade ATX Mid Tower Case  ($24.99 @ NCIX US)
Keyboard: Cooler Master Devastator II Wired Gaming Keyboard w/Optical Mouse  ($19.99 @ Newegg)
Total: $850.88
Generated by PCPartPicker 2016-11-25 21:28 EST-0500
https://linustechtips.com/topic/697128-first-build-advice/#findComment-8923566
Maybe next time lol
My Current Rig:
https://linustechtips.com/topic/697128-first-build-advice/#findComment-8923569
I'm going to assume you have a 1080p60hz panel since you didn't specify...
https://pcpartpicker.com/list/kpBK2R
made some changes since your original spending was horribly imbalanced imo and included some low end parts. There are some rebates to be had on here, but you're also currently under 850 even with the cost of windows, so you should be fine whether or not you do your rebates.
https://linustechtips.com/topic/697128-first-build-advice/#findComment-8923591
35 minutes ago, TurkeyClub said:
Omg!  It said 40 when I clicked on it!  Thanks for pointing that out!
we have close budge and I lean more on the cpu too, I would get a better power supply for the long term
here's mine https://pcpartpicker.com/list/YbrkgL
https://linustechtips.com/topic/697128-first-build-advice/#findComment-8923845
Yeah, I do a bit of music production and light mainstream gaming.  Get the CPU on jet.com with Triple15 for 189 on the 6600k, then put that on a z170 mobo so you can overclock.  I'm looking at the 550 cxm for those nice black cables, none of that ketchup mustard, but on a budget, not so sure.
https://linustechtips.com/topic/697128-first-build-advice/#findComment-8924095
