The current graphics card i have is the GTX 950 which is fine for what i do (mainly CS:GO) and i just bought a 144hz monitor for black Friday and i was wondering if the dvi port the monitor will fit in my GPU.
GPU: https://www.amazon.com/EVGA-GeForce-Cooling-Graphics-02G-P4-2958-KR/dp/B013WQC9U2/ref=sr_1_2?s=pc&ie=UTF8&qid=1480117603&sr=1-2&keywords=950
Monitor: http://www.newegg.com/Product/Product.aspx?item=N82E16824009642
The GPU has a div-I and the monitor port is a dvi-d and i was wondering of one it will fit, and two if it does will it support the 144hz?
https://linustechtips.com/topic/697053-help-with-ports/
