Hello people!
So I built this PC just now, everything seems to be working smoothly with an exception of inconsistent internet connection.
I can install drivers to make it work (ofc), but after EVERY reboot I have to uninstall and reinstall to be able to connect.
When I have rebooted it says that it finds the router but no internet connection from it.
Another PC finds it just fine, also with cable.
It feels REALLY annoying to reinstall drivers every time, and I read somewhere that getting a network card could solve this.
I do feel like that shouldn't be necessairy since.. Well it is physically working. When I have reinstalled it there are no hiccups or drops, it works fine.
I personally feel like it could be a driver issue.. But how?
Thanks!
https://linustechtips.com/topic/696922-internet-connection-issues/
15 minutes ago, MVPernula said:
Hello people!
Thanks!
You could try contacting your board manufacturer, if its faulty you can get a replacement.
