Hey, I got me two case fans however I only have one case fan plug on my motherboard so I have them plugged in by molex meaning they are running full speed all the time, therefore noisy and probably reducing their life span, basically I want to know if there is a connector to plug two fans into one case fan plug on the MOBO or what I have to do in regards to this, I tried just googling things like molex to 4 pin and stuff but never found anything that looked right so I figured I'd ask someone who knows
https://linustechtips.com/topic/695676-case-fans/
Quote
On 24/11/2016 at 1:08 AM, RKRiley said:
A fan splitter will do the trick, assuming the fans also have a 3 or 4 pin connector on them
if they have 3/4 pin - https://www.amazon.co.uk/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=fan+splitter
On 24/11/2016 at 1:07 AM, Chris_R. said:
Thanks both of you, looks like those would do the trick, I swear I searched that exact thing but whatever.
https://linustechtips.com/topic/695676-case-fans/#findComment-8929667
