Hey folks, I'm new to PC building, specifically the anesthetic part of the process. I'd love some case recommendations to go with the hardware I've already bought when they were on sale. I'd love a sidepanel, preferably tempered if possible. I don't really have that many requirements I just want something that will look good with the rest of my stuff as I don't really have a good grasp of what parts look like together. My budget is around 100, but I could sacrifice 8gb of ram to go to 150$ or so.
Here are the parts I have so far:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130902
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500362
http://www.newegg.com/Product/Product.aspx?Item=9SIA4UF2DZ6565
Thanks for any and all suggestions, feel free to ask questions.
https://linustechtips.com/topic/693972-case-suggestion-for-first-build/
well for anesthetic im not a doctor so cant help but for aesthetics what do you like in a case colour finish do you like simple or complicated do you want room to expand in the future?
build: Frankenstein http://au.pcpartpicker.com/list/QLBRVY
i know it's nuts but the drives i bought over time as i need more storage.
I'll never go bigger than an ATX and one Graphics card. Preferably a back/white case
6 hours ago, Spitfire1911 said:
i agree with this one. i just got one and it is amazing. he is very spacy and perfect for airflow because the hardrives can fit underneath the cover. the glass looks just gorgeous and shows your parts perfectly. cable managing is also verry nice with this case
