Okay, So i'm getting a new case soon and I've watched far too much LTT to not have cool LED lights in my case to make it look even more sexy, i've been looking at some on amazon and they mostly look quite cheap and nasty and often really short in length, what's the best LED lighting (preferably RGB) that isn't going to make my wallet cry, some are expensive i know, these are going in the case so that makes it a bit more difficult.
https://linustechtips.com/topic/693312-best-led-strips/
SUPERNIGHT USB RGB LED Light Strip 5050 Flexible Adhesive Tape Multi-color Changing Lighting Kit for Flat Screen HDTV LCD Desktop PC Monitor(0.9Meters, 27LED) https://www.amazon.com/dp/B01EFIQ91G/ref=cm_sw_r_other_apa_aWmmybV3VTY3Y
I have it for my pc
Everyone should own a vive.
https://linustechtips.com/topic/693312-best-led-strips/#findComment-8888691
If you want a premade solution that is plug and go Cable Mods and others such as Bitfenix, Addoncustoms and Modguru have good LED kits.
However if you don't mind doing some DIY work as said you can get a roll of LED's off Amazon and cut them to length and wire them up.
-Moved to Modding Section-
https://linustechtips.com/topic/693312-best-led-strips/#findComment-8889149
