I need some help understanding what part does this
Solved by Mr_KoKa,
Ok, this is whole different story.
You need to remove margin from form style, it is now:
form { margin: 0 0 2em 0; }
And there is margin for buttons, style is:
input[type="submit"].fit, input[type="reset"].fit, input[type="button"].fit, .button.fit { display: block; margin: 0 0 1em 0; width: 100%; }
So it has to be remove too, and you would probably want to remove margins from forms and inputs only when they are inside table cell, so what I would suggest is adding this style at the end of css so it overwrite those margins (only when they are inside table cell):
td form { margin: 0; } table td input[type="submit"].fit, table td input[type="reset"].fit, table td input[type="button"].fit, table td .button.fit { margin: 0; }
You could join these but if you leave it separate for form and buttons it will be easier do read.
