my friend is building a new pc and he picked a chassi that didnt fit all his parts so i said he could send it back and go for the Cooler Master MasterCase Pro 5. is this a good choice? these are his parts: https://www.inet.se/kundvagn/visa/9900742/
Watches and computers
https://linustechtips.com/topic/693143-cooler-master-mastercase-pro-5/
It's a fine choice. Most mid towers from NZXT, Corsair would also fit this build.
Main Rig
CPU: Ryzen 2700X
Cooler: Corsair H150i PRO RGB 360mm Liquid Cooler
Motherboard: ASUS Crosshair VII Hero
RAM: 16GB (2x8) Trident Z RGB 3200MHZ
SSD: Samsung 960 EVO NVME SSD 1TB, Intel 1TB NVME
Graphics Card: Asus ROG Strix GTX 1080Ti OC
Case: Phanteks Evolv X
Power Supply: Corsair HX1000i Platinum-Rated
Radiator Fans: 3x Corsair ML120
Case Fans: 4x be quiet! Silent Wings 3
3 minutes ago, smiles rising said:
i would pick the H440 but he wants the 5.25 slot so i picked this
I use an H440, with a similar motherboard and a 1070, fits perfectly. Why does he want a 5.25 bay? Is he new to PCs, as I can't see a reason anyone would need them..
Main Rig
CPU: Ryzen 2700X
idk why he wants it.. he just said "i want it" so i dont want to argue.. will his cooler fit the case?
