Aight so.. helping my father with his new build...
He has a m.2 drive he just bought and we saw the bios wasn't detecting it so we looked around and found we needed to enable it via the bios but now here the problems.. We only get 2 options
SATA Express or M.2
When we enable M.2 his SSD's arn't detected and when we enable SATA Express his M.2 doesn't work and Windows doesn't detect the M.2 atm..
If we were to install Windows on the M.2 would it possibly detect the SSD's even tho they arn't being detected in the bio? I'm gonna say no but idk..
The board says it supports BOTH M.2 and SATA soo what gives?
https://linustechtips.com/topic/692929-z170-e-ssdm2-problems/
what's the specific board?
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/692929-z170-e-ssdm2-problems/#findComment-8885199
Just now, Dimmizer said:
ASUS z170-e
and the CPU?
https://linustechtips.com/topic/692929-z170-e-ssdm2-problems/#findComment-8885205
1 minute ago, Dimmizer said:
has a Intel i5 6500 Skylake
M.2 shares SATA mode with SATA Express. Change this item before installing M.2 SATA devices.
you don't happen to have your SSDs plugged into sata express, do you?
https://linustechtips.com/topic/692929-z170-e-ssdm2-problems/#findComment-8885217
3 minutes ago, deXxterlab97 said:
the title
i'm blind af
https://linustechtips.com/topic/692929-z170-e-ssdm2-problems/#findComment-8885221
Ahhh so we gotta move the SSD's away from SATA Express? because yes I believe his SSD's are in the SATA Express slots. :D
https://linustechtips.com/topic/692929-z170-e-ssdm2-problems/#findComment-8885228
can't hurt to try
https://linustechtips.com/topic/692929-z170-e-ssdm2-problems/#findComment-8885232
unplug everything and leave only the m.2 in he motherboard
=======================Current Build=======================
Motherboard: ASUS Z170-AR
CPU: i5-6600k @ 4.5Ghz Overclocked
GPU: Gigabyte GTX980 @ 1200 Mhz Oveclocked GPU boost 1400Mhz
Memory: Corsair Dominator 16Gb @ 3200 Mhz
Cooler: NZXT Kraken x61
Storage: Corsair Force GS 128Gb + WD2TB + Seagate 1TB
PSU: Corsair HX650
Lighting: NZXT HUE+ with extension
Display: LG 34' Ultrawide 3440x1440
Peripherals: Razer Blackwidow x Chroma + Razer Firefly + Razer Mamba Chroma
Headphones: Astro A40 + Miniamp
https://linustechtips.com/topic/692929-z170-e-ssdm2-problems/#findComment-8885273
