I looked to see if your GPU could fit this case and it does, and it goes with your budget. Though, I'm not great at suggesting things, but regardless I'd like to suggest this case: https://www.amazon.com/Xigmatek-Aquila-Micro-ATX-Computer-CCD-14AWW-U01/dp/B00PCZHIVW/ref=sr_1_8?ie=UTF8&qid=1479507691&sr=8-8&keywords=matx+white+case
https://linustechtips.com/topic/692804-matx-white-case/#findComment-8884126
Thanks guys.
Unfortunately, those recommended cases weren't available here in my country.
Xigmatek Aquila was viable, but again, unfortunately, stocks were depleted already. Specially the white one.
I opted for the Fractal Arc Mini R2 instead. Less hassle for thinking if my GPU will fit the case.
I'll just have it modded instead.
Thanks.
https://linustechtips.com/topic/692804-matx-white-case/#findComment-8894793
