What's up guys, I'm not sure this is the right place to ask this but I'm going to give it a shot anyway. I'm trying to figure out how to make combinations using this data set: 34, 23, 299, 15, 7, 32, 45, 50, 13, 7 . The combination has to be 10 choose 8 so there is 45 combinations in total. Is there a function in excel that can help with this?
https://linustechtips.com/topic/692167-excel-help/
Can you translate that into a math equation or rephrase, not sure I understand
https://linustechtips.com/topic/692167-excel-help/#findComment-8877145
So I have to create 8 number combinations without repetition using the 10 number data set above. So like 34,23,299,15,7,32,45,50 as the first combination, repeat 44 times. As you can guess this gets complicated fast and I thought excel might have a function built in to slove this.
https://linustechtips.com/topic/692167-excel-help/#findComment-8877164
I don't think there is, unless you can translate that into an equation
https://linustechtips.com/topic/692167-excel-help/#findComment-8877167
