Hello, my friend is looking to build a computer. He has a budget of around $800 USD but is willing to go up to 1000. He does not need peripherals, and you can add windows 10 for $40 from Kinguin to your budget. I have found these keys to work well. We also have a microcenter and fry's near us for in store purchases. He wants to play games on this.
Thanks for the help
https://linustechtips.com/topic/691999-new-build-help/
check the microcenter I know the one I live near has a motherboard/cpu combo sale. also /r/buildapcsales tend to have a lot of fry's and microcenter deals listed.
CPU-i7 6700k O.C. 4.6Ghz-Motherboard-Asus z170-a-RAM-24gb DDR4-GPU-EVGA GTX 1080 FE-Case-Corsair 400c (white)-Storage-HDD: 2xWD Blue 1TB SSD: PNY SSDSC120GLC709B121-510 120GB-PSU-1000 watt coolermax-Display-ASUS VG248QE Black 24" 1080p 144 Hz -Cooling-Corsair H115i-Keyboard-G.Skill KM780 Cherry MX blues (Red backlight)-Mouse-Logitech G602-Sound-Logitech 5.1 z506
Need a budget headphone for under 100$? Sennheiser HD 558 Headphones
Got a Skylake CPU (k) Here is a guide to OC it!
https://linustechtips.com/topic/691999-new-build-help/#findComment-8875126
You're welcome
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($235.49 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.88 @ OutletPC)
Motherboard: ASRock Z170A-X1 ATX LGA1151 Motherboard  ($91.99 @ SuperBiiz)
Memory: Avexir Core Series 16GB (2 x 8GB) DDR4-2400 Memory  ($69.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.89 @ OutletPC)
Video Card: MSI GeForce GTX 1070 8GB Video Card  ($389.99 @ B&H)
Case: BitFenix Nova ATX Mid Tower Case  ($36.99 @ NCIX US)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($54.99 @ B&H)
Total: $953.21
Generated by PCPartPicker 2016-11-16 23:22 EST-0500
https://linustechtips.com/topic/691999-new-build-help/#findComment-8875131
Thanks for the help
Do you live in SouCal by anychance?
https://linustechtips.com/topic/691999-new-build-help/#findComment-8875135
You can fit a 1070 and 6600k in the build but you will have to remove the SSD and get a cheaper motherboard and cooler.
CPU Cooler: be quiet! Shadow Rock Slim 67.8 CFM Rifle Bearing CPU Cooler  ($34.90 @ Newegg)
Motherboard: Gigabyte GA-Z170MX-Gaming 5 Micro ATX LGA1151 Motherboard  ($128.99 @ NCIX US)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  ($51.99 @ NCIX US)
Storage: Samsung 120GB 2.5" Solid State Drive  ($54.89 @ SuperBiiz)
Video Card: MSI GeForce GTX 1060 6GB 6GB GAMING X Video Card  ($272.89 @ OutletPC)
Case: NZXT S340 Elite (Black) ATX Mid Tower Case  ($89.99 @ SuperBiiz)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($54.99 @ Amazon)
Total: $973.02
i5-6600k (4.6) | Dark Rock 3 | MSI GAMING X 1060 6GB | 8GB DDR4 | 120GB SSD & 1TB HDD | Crystal 460x
 | Acer GN246HL 1080p 24" 144hz & Acer G246HL 1080p 24" 60hz |
PSU Tier List | PC Partpickers: US Canada Australia UK
https://linustechtips.com/topic/691999-new-build-help/#findComment-8875141
2 minutes ago, deXxterlab97 said:
At $1000 a SSD should be included.
https://linustechtips.com/topic/691999-new-build-help/#findComment-8875149
Just now, deXxterlab97 said:
I leave 40 dollar for OS.
I feel like the 1070 is forced in your build, you compromise on most things to fit it in. You can save money by removing the 16GB and getting 8GB.
https://linustechtips.com/topic/691999-new-build-help/#findComment-8875166
@Sreno1
@Apollo Refugio
Now you all happy????
CPU Cooler: CRYORIG M9i 48.4 CFM CPU Cooler  ($19.99 @ Newegg)
Storage: PNY CS1311 120GB 2.5" Solid State Drive  ($39.99 @ Best Buy)
Storage: Hitachi 1TB 3.5" 7200RPM Internal Hard Drive  ($39.00 @ Amazon)
Video Card: Gigabyte GeForce GTX 1070 8GB Windforce OC Video Card  ($379.49 @ SuperBiiz)
Total: $967.92
Generated by PCPartPicker 2016-11-16 23:30 EST-0500
https://linustechtips.com/topic/691999-new-build-help/#findComment-8875196
@Sreno1
@Apollo Refugio
Total: $967.92
dafaq, 120 GB???????
AMD Ryzen 7 7800X3D | Sapphire Pulse AMD Radeon RX 7900XT Triple Fan | G.Skill 32GB 2x D5 6000
https://linustechtips.com/topic/691999-new-build-help/#findComment-8875205
he already has a budget of 800 and willing to go up to 1000. He will not most likely go over that. Unless you can find me a free legit copy of windows
nvm, i just did a quick build on PCPP, and i reached a $1000 limit without including a decent case. rip
https://linustechtips.com/topic/691999-new-build-help/#findComment-8875218
How is this? http://pcpartpicker.com/list/Hf6TPs
There is a mobo/cpu combo at microcenter for 250 and those are the components. I added 20 for tax. The gpu is a 6 day sale on Newegg at 405 with 20 rebate. Is there any way I can shave off any more?
@Apollo Refugio @deXxterlab97 @Sreno1 @GalacticRuler
https://linustechtips.com/topic/691999-new-build-help/#findComment-8875275
please not a h170 motherboard as you can not overlock on it. if i were you i would try and get a cheaper gpu, way cheaper ssd as samsung are epxpensive
look my 2 builds I posted up there, they are perfect
https://linustechtips.com/topic/691999-new-build-help/#findComment-8875282
I did this just to show an i7 and 1070 can be put in the same build. I know theres some cut backs and the 2nd 8gb would have to added later :D
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  ($289.99 @ B&H)
Motherboard: ASRock H170A-X1 ATX LGA1151 Motherboard  ($53.98 @ Newegg)
Memory: Kingston FURY 8GB (1 x 8GB) DDR4-2400 Memory  ($42.98 @ PCM)
Case: BitFenix Comrade ATX Mid Tower Case  ($29.99 @ NCIX US)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($42.39 @ OutletPC)
Total: $947.69
Generated by PCPartPicker 2016-11-17 00:00 EST-0500
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/691999-new-build-help/#findComment-8875304
http://pcpartpicker.com/list/ZKFc4C
cpu: intel i5-6500 3.2 ghz quad-core
mobo: asus h170m-plus MATX
(if you want to push the budget further for more graphics/performance up this to a z170 board and a "k" series processor, and think about only using a single ssd or hdd)
memory: corsair vengeance lpx 2x8 ddr4-2133
storage: adata ultimate su800 256gb 2.5" ssd
              wd caviar blue 1tb 3.5" 7200rpm hdd
gpu: sapphire radeon rx 480 4gb nitro+
(I think amd has the best value at not super high end pc's but if he prefers NVidia, a 6gb 1060 would also serve him well)
case: fractal design arc mini r2 MATX
Power supply: corsair cxm 550w 80+bronze semi-modular psu
total price including $40 OS = $883.00 just going off of pcpartpicker.
however, I know for a fact that microcenter has a $30 off with cpu if you purchase a mobo with it, black Friday is coming and you should be able to snag ram a bit cheaper, for a $10 premium the cxs corsair line of psu's will be 80+gold if that bronze rating is worrisome.
Justification/explanation for choices: non "k" chip and h170 board to save money (also not having to buy a cooler), wont need to OC to play perfectly at 1080p 60fps and the pricepoint makes 1440p kind of unreasonable (have to compromise to fit a gtx 1070 in there), corsair is a great RAM brand and that's the cheapest set there is and 2x8 is the standard for most builds, I think <250gb ssd's are kind of dumb (with this amount you can throw more than a couple of your fav games and your OS on there) and a 1tb drive for mass storage, any rx 480 would do just fine or gtx 1060 for that matter (this one is cheap and not sketchy to me), i personally have a 4k gaming rig in a arc mini r2 its a fantastic case at the price but for $30 you can find some decent enclosures, and 550w is all youre going to need and cxm/cxs are just fine for psu's. i also went with the matx form factor, as it still allows plenty of expansion while keeping the not massive footprint of atx towers. if he wanted to crossfire or add a soundcard or even double his ram in the future; he can.
https://linustechtips.com/topic/691999-new-build-help/#findComment-8875391
Thanks for the help
oh also, check out sites like techsource.tech for some occasional really good deals. especially on SSD's and mid-range gpu's and such
https://linustechtips.com/topic/691999-new-build-help/#findComment-8875404
