Fan Control Software?
7 minutes ago, wrathoftheturkey said:
You usually can't control fan speed from the OS can you? Besides CPU and GPU I'm pretty sure it's automatic?
If you can, I've heard good things about SpeedFan
It's automatic, I just want software to where I can manually set it.
https://linustechtips.com/topic/691952-fan-control-software/#findComment-8874521
8 minutes ago, VinZie said:
MSI Afterburner
MSI Afterburner only controls GPU fans.
https://linustechtips.com/topic/691952-fan-control-software/#findComment-8874532
Just now, VinZie said:
Does it really? The PC I am using is loud with the 1 case fan I have.
I've been using it for years, and never found any option to control other fans.
https://linustechtips.com/topic/691952-fan-control-software/#findComment-8874548
Yolo
Uh huh.
You're controlling the GPU fans.
https://linustechtips.com/topic/691952-fan-control-software/#findComment-8874553
2 minutes ago, VinZie said:
Well shit. I am keeping it %100 speed tho
This is what happens when I change the fan speed to 60%. Bear in mind that my 970 is the card that's selected. My second GPU(560 Ti) remains unaffected
And back to 40%:
https://linustechtips.com/topic/691952-fan-control-software/#findComment-8874573
4 minutes ago, lilbman said:
I can't use Speedfan or MSI Afterburner.
Any other good ones??
I'm not sure that you'll even be able to control the fan(s). What laptop are you using?
https://linustechtips.com/topic/691952-fan-control-software/#findComment-8874576
  Hide contents
And back to 40%:
  Hide contents
Very nice
https://linustechtips.com/topic/691952-fan-control-software/#findComment-8874577
Alienware 15 R3
It's in my signature
Try using Alienware Command Center:
Bear in mind that this is a direct download link if you don't already have it installed: http://downloads.dell.com/FOLDER03882773M/6/App_DT_AWCC4.7.7.0_W10_Setup_8D5GP_ZPE.exe
https://linustechtips.com/topic/691952-fan-control-software/#findComment-8874613
I know. But Alienware is over priced. You can get a desktop that easily runs 4K for a Alienware laptop.
Let's stick to figuring this out, and not arguing about Alienware.
https://linustechtips.com/topic/691952-fan-control-software/#findComment-8874619
This is worth a try.
https://linustechtips.com/topic/691952-fan-control-software/#findComment-8874627
