Compressed air safety
Solved by dalekphalm,
Just now, Forest_Penguin said:Thanks, is it dangerous to use around capacitors that have been on recently?
As long as you're not putting the nozzle 1cm away from it, yes it's safe. You want to hold the nozzle around 6-8 inches away from the surface.
If you notice actual liquid shooting out, you need to let the can sit untouched for a while (It'll also become super cold to touch) - you need to let it sit until it returns to room temperature.
If the capacitors are hot to the touch, however, wait until they've cooled down. Heat + flammable gas = fire. The caps can be warm, but should be comfortable to touch with your fingers.
