They certainly exist, although most people prefer custom loops. A few examples are the NZXT Kraken G10 or the Corsair HG10 A1.
EDIT: these are mounting brackets to use with regular CPU coolers, although I know people who just ziptie CPU coolers on.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
NZXT has made a bracket where you can water cool the GPU dye with a CPU cooler.
https://www.nzxt.com/products/kraken-g10-white
Some graphics cards also come water cooled but you are paying a higher price compared to air cooled cards. Or the usual route of just creating a custom loop which consists of the gpu block, pump, radiator, etc.
These are the ways I can think of water cooling a gpu
yes, there are AIO coolers that exist for GPUs. for example my 1070 EVGA card has a hybrid kit installed but the kit itself is sold separately so you can DIY. however you'll have to check in to see if the AIO kit can work with your card, and consider mounting space
here is another example https://www.pcper.com/news/Graphics-Cards/Alphacool-Launches-Expandable-Eiswolf-AIO-GPU-Coolers these are only for the 1070 and 1080 though
