For almost the past year my gaming pc will just freeze randomly with a horrible buzzing or static noise in my headphone.  Basically I will being doing stuff from playing Gta 5, to even just writing an email (With nothing else open in the background) and the whole computer will freeze up and does not recover.  I have windows 10 (Up to date) and one time when i was playing gta 5 and the Blue screen did end up happening , but that was the only time it has happened and it also had the buzzing sound as well.  What is the problem?  Is it hardware or is it software or anything else?  This has been going on for far too long and i need a solution because it's getting in the way of my work.
20161023_162008_1.mp4
https://linustechtips.com/topic/691517-pc-randomly-freezing/
Specs? Temps and Usage? Do you download anything off shady websites?
https://linustechtips.com/topic/691517-pc-randomly-freezing/#findComment-8869378
20 hours ago, linuxlove said:
can be a lot things, but would first start with GPU. It can still potentially by CPU, RAM, Motherboard related as well. Check the system event logs it may give you more information about the bluescreen crash on why it happened.
Where can i find the event logs?
https://linustechtips.com/topic/691517-pc-randomly-freezing/#findComment-8874629
