Hi, I just recently built my first Pc and I wanted to overclock the Graphics card, so I started researching.
I want to make sure everything i'm doing is correct and wont kill my GPU by over voltage.
I use MSI Afterburner and I overclock my GPU about 10%.
GPU: MSI RX 480 8gb
Default Clock Speed: 1303 MHz
OverClock Speed: 1415 MHz
Default Memory Speed: 2000 MHz
OverClock Memory Speed: 2250 MHz
Default Voltage Avg: 1100 mV
OverClock Voltage Avg: 1150 mV
Power Limit: +20%
Thanks in advanced!
https://linustechtips.com/topic/690788-rx-480-overclock-help/
Increase the power limit to the max
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/690788-rx-480-overclock-help/#findComment-8860904
