Power throttling
7 hours ago, danyaldaniamed said:Hey, I have an asus 1080 strix water cooled. It is runing at 62 max under max loads, and idling on 20ish. The problem is when I overclok it I can achieve 2127Mhz easily and stable for some time, than It starts throttling, and goes down to 2050 something. I have been checking the temps in game, they never reached even 63. I think it is power throttling, I have set the core voltage to 100%, power limit 120% and so. as you see in the picture below.
I cannot keep it running on 2.1Ghz, Any help is appreciated.
Open up GPUz to the sensors tab. Watch the "PerfCap Reason" line. Do some testing, and if you see green, indicating "PWR" perf cap, then yes....you're hitting a power limit throttle.
Given the temps that you're talking about though, you're likely just seeing the core throttle down due to temps. There are temp points that the GPU core will reach, and "throttle" to the next voltage up, or the next clock down, depending on the curve you chose to employ. You're using a stock curve with a +160 offset.....this would indicate to me that this is what you're seeing, and not a power limit throttle.
Those layers exist, with boost 3.0 every 10c or so, starting at 25c. You can avoid them, somewhat, by using a custom voltage/frequency curve. Like in the attached picture, below.
