So after a long while, I'm finally upgrading my GPU; I have my heart set on a 1070 BUT as I scour the retailers online I am struck with a dilemma, should I go with a hybrid GPU like this : http://www.evga.com/Products/Product.aspx?pn=08G-P4-6178-KR
OR something else ?
Things to consider
- I will be using this card for at least 3 years
- I will be USING 2 monitors > 2560 x 1080(video editing) and 2560x1440(gaming)
- I will be overclocking
- I DO care about aesthetics
TL;DR : Is a hybrid GPU good for long term usage, are there any risks.
https://linustechtips.com/topic/690206-hybrid-gpu-or-not/
The main risk is that the card might leak, but I don't think I've heard any of that from people who have bought the Hybrid 1070. Do you have a mounting point for the radiator in the chassis?
https://linustechtips.com/topic/690206-hybrid-gpu-or-not/#findComment-8854341
Card leakage is a risk I'm willing to take but pump failure after a couple of years would be quite the bummer for me.
https://linustechtips.com/topic/690206-hybrid-gpu-or-not/#findComment-8854355
The warranty is for three years.
https://linustechtips.com/topic/690206-hybrid-gpu-or-not/#findComment-8854359
I will be importing it via a friend since it's too expensive where I live ($600) so IDK if I can get a warranty that way.
Also I've heard horror stories of card dying just out of warranty and I DO NOT want to be in that situation; no one does.
https://linustechtips.com/topic/690206-hybrid-gpu-or-not/#findComment-8854367
The problem is that no one can predict if that's going to happen, doesn't matter what card it is.
https://linustechtips.com/topic/690206-hybrid-gpu-or-not/#findComment-8854373
2 minutes ago, Stealthymastercat said:
The pump failure or leakage is my only concern since I can't take that kind of a hit on my only PC.
then go with an aircooled card the GTX 1070 is a cool running chip anyways...just don't get a blower style cooler.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/690206-hybrid-gpu-or-not/#findComment-8854402
Then you can go purchase one of their cards(or someone else's) that's "air-cooled" if you're afraid of either of those things.
https://linustechtips.com/topic/690206-hybrid-gpu-or-not/#findComment-8854404
