Im ussually pretty good on modding things myself but ive had the Corsair 500r case for a while now and im using it for my next build, im looking to do it as a black and red build http://pcpartpicker.com/list/h4pL4C i need ideas on how to make the case fit more of the red and black theme ( i unfortunately have the white one) ive thought of painting it red except for the black parts but idrk any ideas is appreciated thanks
https://linustechtips.com/topic/690011-modding-my-case/
8 minutes ago, ShadowTechXTS said:
I'd recommend one 1080 instead of two 480s because Crossfire isn't supported in all games.
Anyway you could use plastidip to paint it and mask off parts you don't want painted, if you mess up it's removable.
ive thought of the plasti dip and or just high heat paint i dont think i would be removing it and i chose the to 480's because one would be an immediate option and i would later down the road get another and ive seen 480's are good in dx12 which is getting more and more accustom also dual gpu use in games being supported more idk ill have to wait
https://linustechtips.com/topic/690011-modding-my-case/#findComment-8852873
