Hi everyone
I was on pcpartpicker the other day and when it came to choose that all important cpu, I got confused.
The Intel i5 6400 has a clock speed of 2.7 ghz and has four cores. All of this for about $150-170 US.
Then I found the AMD FX 8350 with 6 cores and has 3.9 ghz that can be overclocked further. This was also cheaper at $120.
So my question is which is worth buying for the money? Is the AMD fx 8350 out of date?
Please help
thanks
https://linustechtips.com/topic/689376-first-time-pc-builder-looking-for-help/
i5 6400 is better. Although it has fewer cores, fewer more powerful cores beat more less powerful cores @Turtleloverdyl
                  CPU: Intel Core i5 6400 ~ ASUS GTX 950 OC STRIX GB ~
                           RAM: HyperX Fury DDR4 16GB dual channel
MOBO: Gigabyte GA-H170-HD3 ~ SSD:HyperX Savage 240GB  ~  PSU: Corsair CX550M
 ~ MOUSE: Logitech G700s ~ KEYBOARD: Razer Blackwidow tournament
            HEADPHONES: Focousrite HP60  ~ MIC:Focusrite CM25 ~ A.I: Focusrite Scarlett 2i2 ~ MONITOR: Asus VC239H 23-inch IPS Monitor ~ CASE: Fractual Design define R4  ~ Corsair MM300 Medium
11 minutes ago, Turtleloverdyl said:
Hi everyone
Please help
thanks
For gaming, definitely the 6400. the 8350 is less efficient and has slower cycles  (i think). wait for intels kaby lake and AMD Zen to come out, and you might see some difference
