Hello Guys, my name are Emmanuel Owoniyi. I want to thank you for doing this video. I seriously need you guys help to build my own workstation. My budget is $1200. I am an Architect, this are the list of software I use for my design. 3dsmax, V-Ray, Artlantis studio, ArchiCAD and Sketchup. Pls I will really appreciate it if you can help. This is my email address owoboy142@gmail.
https://linustechtips.com/topic/688682-workstation-for-architect/
@those who want to do a built:
these applications are pretty much all multi core whores, the more cores the better.
depending on rendering settings a decent GPU will be also a good idea.
also RAM will be a good idea, lots of it, going along with fast drives.
suggestion from me:
http://pcpartpicker.com/list/qh9RzM - allthough thats around 1400$ not including OS / Optical Drives / Storage Drive / monitor / peripherals
1200 US might be a little llow for what you want to do , and you want it to happen quickly and profesionally, what i propose is a little higher and peripherals aren't included but it will be there for years tto come without a hitch:
It is 1533 US Dollars but i think it will serve you well, only hick up i would put another pair of 16Gb memory in there to be a boss..!!!
Your link doesn't include a list - just a plain PartPicker site :-)
I can open it as a list, whatever here is another list of the same
http://pcpartpicker.com/user/JamieOlive/saved/#view=BWL23C
