So in a roughly about a week, i plan to order the parts for my PC im building.
Here is the parts..
http://au.pcpartpicker.com/list/2MN8HN
What do you see that could be improved?
Keep in mind I don't want to spend any more money on the build unless completely necessary.
Please make some suggestions....
Thanks
-Pat
https://linustechtips.com/topic/688659-need-some-help/
Try to squeeze a 470 in there if possible, its only $50 more.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/688659-need-some-help/#findComment-8838732
2 minutes ago, Sahil10416 said:
You should buy a rx470(4gb) rather than buying a 1050ti bcz the performance difference is huge but the price difference is little.
Also buy a single ram stick (8gb) so that you can upgrade your ram in the future.
i cant find any single ram stick (8gb) that look nice like the kingston fury in my list for a price that isnt ridiculous.
Also id rather get a 1060 3gb then a rx470, = if im going to spend 50 dollars more
https://linustechtips.com/topic/688659-need-some-help/#findComment-8838736
