Hi! I want to start off my building a reasonable less-than 800 USD pc. I listed what I chose, and it's cost. (I'm in indonesia. 1 USD = ~13,100 IDR)
Processor: I5-4690k                               1,580,000 IDR              -              ~121$
Mobo: AsRock H81M HDS                     787,000 IDR               -                 60 $
RAM: Crucial Ballistix Sport 2x4 gb       1,070,000 IDR              -               ~82 $
Storage 1: Samsung 750 Evo 250 gb     1,030,000 IDR              -              ~81.5 $
Storage 2: 1TB WDC Caviar Blue           695,000 IDR                 -                53 $
GPU: Galax geforce GTX 1060 6 gb       3,150,000 IDR             -              ~ 240 $
PSU: Corsair CX 500W Bronze +            885,000 IDR               -                68 $
Monitor: Undecided but 1080p 27in     probs over 1,500,000 IDR             ~114$
OS: Win-10 home                                    1,465,000 IDR            -               112 USD
Other: Tp link Wifi card                             Unknown                                    Unknown
I already have the peripherals and I will mount my pc to my desk, so I won't have a case. I still don't have a monitor but I am over my 10 million IDR budget. What monitor should I get and how can I lower other part's prices? Thanks! (I would like to keep the GPU tho)
The PC parts will be bought from enterkomputer.com They are known to be the cheapest place to buy PC parts.
P. S. GTX 1050s aren't out in indonesia rn.
https://linustechtips.com/topic/688615-pc-building/
Have you checked other stores? I've noticed that places known for cheapest pricing don't always have cheapest prices. And side note, cheez it sounds so silly to hear you talk about 10 million IDR monitor after watching Linus' 8K TV video.
One problem I notice is your CPU and mobo combination. Are you going to OC? If yes, then you need to get Z-chipset board. You can't OC on H81 chipset.
1 hour ago, BenoitWW said:
try using pcpartpicker to figure out cheapest prices. Everything looks pretty good to me. Do you really need wifi though or can you just use ethernet?
PCPPs problem for countries that aren't in it, is that it includes options which aren't available everywhere.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/688615-pc-building/#findComment-8838536
Yes, I have checked other stores, and since there aren't many, there is no competition. Other stores sell the 3 mil IDR gpu for as much as 7 mil. Also, what do you mean about the the 10 mil idr monitor?
Idk, I just copied my friend's build and changed the gpu and ram, psu around. I guess I'll have to change to a z-chipset board.
I believe pcpp doesn't suggest local stores and also, if you're thinking about internet shopping, they ship from the US which the shipping fee costs as much as my ram.
https://linustechtips.com/topic/688615-pc-building/#findComment-8838913
