Hello, LTT forums!
SO, basically, I need about 4 feet of LED's, I want them to be RGB, and I would like for the whole thing to cost under or around $30. I heard the thing to do is buy any RGB LED kit and get a power converter to run the little box off of a molex cable or something? Go from DC to AC current or vice versa, however it goes.
I wanted to know if this was a safe thing to do in your computer, and I was wondering if anyone could recommend any lights and a method of power conversion?
Thanks!
CPU: i7 6700k     Cooling: Asetek 550LC     Motherboard: MSI Z170A Gaming PRO Carbon     RAM: 2x (4GB ADATA XPG)
GPU: ZOTAC GeForce® GTX 1080 AMP Extreme     Storage: 128GB SSD, 2TB HDD     PSU: 800Watt 80+ Bronze    Operating System: Windows 10
Case: NZXT S340
https://linustechtips.com/topic/688582-rgb-led-help/
