it's the stock cooling I can't remember what it is though.
Is the CPU overvolted? and what CPU are you using?
You might want to look into something like the Coolermaster 212 EVO if you just wnat the CPU cooled down
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/68836-cpu-cooling/#findComment-943953
This belongs in Air Cooling, but yeah. The EVO can tame that no problem.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/68836-cpu-cooling/#findComment-943965
I just want to know what would be good to use for cooling
Coolermaster 212 EVO would be a good choice, It pretty inexpensive and will do a good job cooling your CPU down.
https://linustechtips.com/topic/68836-cpu-cooling/#findComment-943966
Here are the specs for my stock pc when I got it last year
http://www.newegg.com/Product/Product.aspx?Item=N82E16883229437
man those retailers su*k, 7750 and 6300 what on earth! and its GAMING ULTRA pc LOL and doesnt even have 7770 inside
did you throw in better gpu and PSU?
https://linustechtips.com/topic/68836-cpu-cooling/#findComment-943973
in your bios settings there should be an option to change the rpm of the fan ber degree, sometimes it's set on 0.75% per degree, maybe you should change it to 2% per degree, worked for me
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
https://linustechtips.com/topic/68836-cpu-cooling/#findComment-943976
thats a bit tall order on a FX processor... with stock cooler xD
I put it in like a week after I got my pc
did you change power supply ?
https://linustechtips.com/topic/68836-cpu-cooling/#findComment-943987
