Hey Guys!
Some time ago I bought this mother board ( H8QME-2+) and I can't get it to post. I get one beep and nothing more. The fans spin up and the cpus do produce heat. According to the manual one beep means "Refresh (Ready to power up)", does this mean I have to jump another couple pins or do something else to boot it up? All help is appreciated! Thanks :)
ftp://www.supermicro.com/CDR-A+NVDA2_1.21_for_A+_nVidia_MCP55_platform/MANUALS/H8QM8(E)-2_1.0c.pdf
Samuel Edwards
- IT Engineer and Media Producer -
Religious theology diploma and over half a dozen certificates in Advanced Computing and IT.
Current Project:   Mineral Oil Cooled PC
Just trying to be friendly and help where I can. Have yourself a great day!
Use @SamuelJE for friendly tech help :)
Main PC - "The Genesis"
Mobo   -   Gigabyte GA-H170-Gaming 3
CPU     -   intel i5-6600K 4Ghz on water
GPU     -   MSI GTX970 "Red Dragon"
Case    -   Zalman Z11 Plus (Custom RGB Obviously, It's 2017 bro...)
OSD     -   Crucial 275GB M.2 SSD
SSD     -   Crucial 250GB SATA SSD
HDD    -    4TB WD Green x 2
Disp     -   LG ultra wide Gaming Monitor
Secondary PC - "Jonah"   (Mineral oil PC)
Mobo   -   Gigabyte GA-B250-DH1
CPU     -   intel i5-7500 Under Oil
GPU     -   Nvidia GTX 660 (Favorite and first ever GPU)
Case    -   A Fish Tank W/ Custom Engineered Mounting System (Custom RGB Obviously, It's 2017 bro...)
HDD    -    2TB WD Green
https://linustechtips.com/topic/687657-no-post-one-beep-help/
8 minutes ago, Electronics Wizardy said:
What cpu and ram?
Do you know the cpu+ram good?
quad cpu, had the same problem with my last ones so I replaced them all, still not working so I doubt it's that. And I have tested the RAM and also used known working RAM
Samuel Edwards
HDD    -    2TB WD Green
https://linustechtips.com/topic/687657-no-post-one-beep-help/#findComment-8827315
then its probably a bad board.
https://linustechtips.com/topic/687657-no-post-one-beep-help/#findComment-8827322
Also replaced the board. Managed to get a replacement after I had the same problem with the last one. Another bad one?
Samuel Edwards
HDD    -    2TB WD Green
https://linustechtips.com/topic/687657-no-post-one-beep-help/#findComment-8827324
Do you know your ram works in that board, this is most often a ram issue.
What specific ram + cpu's
Also what are you doing with a old quad socket system?
https://linustechtips.com/topic/687657-no-post-one-beep-help/#findComment-8827338
That was what I was thinking. I'm not sure if they are compatible. I have been told they are fine.
http://www.supermicro.com/Aplus/motherboard/Opteron8000/MCP55/H8QME-2_.cfm
http://www.ebay.com/itm/351397763184?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Samuel Edwards
HDD    -    2TB WD Green
https://linustechtips.com/topic/687657-no-post-one-beep-help/#findComment-8827350
Oh and because I wanted to build a somewhat powerful cheap personal server.
Samuel Edwards
HDD    -    2TB WD Green
https://linustechtips.com/topic/687657-no-post-one-beep-help/#findComment-8827354
Seems like the wrong ram, i think you need ddr3 ecc
https://linustechtips.com/topic/687657-no-post-one-beep-help/#findComment-8827356
Hope you don't mind paying for power.
Id probably stop with this and get something like a dell r710 or a dual 1366 system. These are normally faster aswell.
https://linustechtips.com/topic/687657-no-post-one-beep-help/#findComment-8827358
I'm not sure. It says on the page "Supports up to 128GB DDR2 800/667/533 MHz memory "
Samuel Edwards
HDD    -    2TB WD Green
https://linustechtips.com/topic/687657-no-post-one-beep-help/#findComment-8827360
the memory is not ECC, is that the problem?
Samuel Edwards
HDD    -    2TB WD Green
https://linustechtips.com/topic/687657-no-post-one-beep-help/#findComment-8827364
Lol have fun paying the power bill and mostlikely having the shit beaten out of you server by a recent i3/i5
If you tell a big enough lie and tell it frequently enough it will be believed.
-Adolf Hitler
https://linustechtips.com/topic/687657-no-post-one-beep-help/#findComment-8834258
http://www.supermicro.com/Aplus/motherboard/Opteron8000/MCP55/H8QM8-2.cfm
There's a nice beautiful link on the right that says "tested memory list"
Look at that memory, your memory should match down to the voltage or else expect some issues. This seems like a really old motherboard however...
https://linustechtips.com/topic/687657-no-post-one-beep-help/#findComment-8840898
