Hello, LTT Community!
I am currently looking to upgrade my prebuilt pc mainly because I can't really afford to build one form scratch so please don't suggest that I do that. The current pc is a Gateway DX4860 with a GTX 950 and a 510w Insignia power supply from Best Buy. The parts that I am looking to buy to upgrade it are
SAMSUNG 850 EVO 2.5" 250GB SATA III 3-D Vertical Internal Solid State Drive (SSD) MZ-75E250B/AM
Asus Z170 PRO GAMING ATX LGA1151 Motherboard
I just wanted to know if there are any issues with compatibility, old hardware, etc...
If there is any way that I can make the upgrades even cheaper please let me know.
Also, if I install the new motherboard, will that cause any issues (I don't mind re-installing Windows)
Thank You :)
https://linustechtips.com/topic/687619-help/
the 4820k is no compatible with a z170 mobo, different sockets
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/687619-help/#findComment-8826777
5 minutes ago, thefreshprinceofbellpepper said:
What processor do you reccomend?
Oh that price range, your best bet is an i5, or buy used.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117561
Also, keep in mind that your case may not fit a new motherboard.  You could end up having to buy that too.
Mystery is the source of all true science.
https://linustechtips.com/topic/687619-help/#findComment-8826865
