So simple question, with internal flash I get the photo I want and it shows the flash, but when I use my external Aperlite 700c it's just black, completely like something is out of sync.
I've tried:
New batteries
resetting the settings
changing modes
Nothing works
Also noticed i can't use the manual mode as it does not fire at all same for multi.
Thanks
p.S I am using a 550D
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
https://linustechtips.com/topic/687476-550d-flash-problems/
What exposure setting do you use with the external flash, a lot of third party external units (cheap ones) do not support TTL and likely do not support high speed sync either so your shutter speed has to be no faster than the max sync speed supported by the flash unit.
Any other technical setting, you should consult your camera and external flash manual to see how you can get them to work in all supported modes.
Edited by AkiraDaarkst
That is not dead which can eternal lie.  And with strange aeons even death may die. - The Call of Cthulhu
A university is not a "safe space". If you need a safe space, leave, go home, hug your teddy & suck your thumb until ready for university.  - Richard Dawkins
https://linustechtips.com/topic/687476-550d-flash-problems/#findComment-8825361
Double post by accicent
Current Build :
Laptop:
 CPU:
https://linustechtips.com/topic/687476-550d-flash-problems/#findComment-8825383
6 minutes ago, AkiraDaarkst said:
What exposure setting do you use with the external flash, a lot of third party external units (cheap ones) do not support TTL so your shutter speed has to be no faster than the max sync speed supported by the flash unit.
I've been using a mix of AV/TV but for this i use M; interesting now u mention speed I set it to High speed and go to 1/320 and bam... Dafuk...
Current Build :
Laptop:
 CPU:
https://linustechtips.com/topic/687476-550d-flash-problems/#findComment-8825393
If it doesn't support TTL and high speed sync, then you should just stick to no faster than 1/250th of a second.  Consult the camera and flash unit's manuals.
https://linustechtips.com/topic/687476-550d-flash-problems/#findComment-8825460
Lucky for me the Flash does support ETTL-II and High-speed sync so luckily it works.
Edit: Need to do further testing using other cannon cameras to find out what is going on.
Current Build :
Laptop:
 CPU:
https://linustechtips.com/topic/687476-550d-flash-problems/#findComment-8825464
Lucky for me the Flash does support ETTL-II and High speed sync so luckily it works.
OK then check the manual to see what other settings you need to change.  If TTL and high speed sync are supported, then you should be able to get a nice exposure.  I'm not familiar with your unit, I am familiar with native Nikon and Canon units.
Maybe the power setting of the flash unit is low, perhaps your exposure setting is not correct, and remember to wait for the flash unit to recycle after each shutter release.  Depending on the power output of the unit, it may take a couple of seconds for a complete recycle.
https://linustechtips.com/topic/687476-550d-flash-problems/#findComment-8825472
