2 minutes ago, RevoThePlug said:
http://pcpartpicker.com/list/fJJQRG
This is the first time I will be building a PC and thought i would come here to ask what you guys think and the monitors I picked because I want atleast two im a gamer and I stream and edit videos that why I have the 6700k
you don't need two monitors to do that. You don't even need the 6700k. Don't waste on money on extra things,because I do both of those and I'm fine with one monitor.
  • CPU
    Intel I-7 6700
  • Motherboard
    Msi Z270i Pro Gaming Carbon AC
  • RAM
    16 GB Crucial
  • GPU
    Msi 4gb GTX 960
  • Case
    Corsair 380t
  • Storage
    Seagate FireCuda 1TB
  • PSU
    Random Antec 500w from 2010
  • Display(s)
    Asus VS278
  • Cooling
    Exhaust: LTT NF-F12 Intake: Thermaltake Riing 140mm Orange Heatsink:corsair H75
  • Keyboard
    Logitech G105
  • Sound
    Onkyo 5.1 surround Theater Speakers
  • Operating System
    Windows 10
https://linustechtips.com/topic/686731-first-build-ever/#findComment-8817133
I need two monitors due to multiple facts and I heavy edit and am aiming for the 6700k due to the fact I have the money to buy it and is better for editing
https://linustechtips.com/topic/686731-first-build-ever/#findComment-8817143
Okay by heavy editing I mean I edit a lot but I dont mean for a job I mean specifically for my videos and for some paid jobs and Im looking more to game and two monitors one for doing school work browsing the web or other things while playing games or while im coding.
https://linustechtips.com/topic/686731-first-build-ever/#findComment-8817166
Looks like a solid build man! If you want 2 monitors then get them, I have three and I don't use them that much with no regrets. The only thing I might recommend is a different case, Doesn't make much sense to dump so much money into components then throw it all in a low end case. I might recommend this one:
http://www.newegg.com/Product/Product.aspx?Item=9SIA68V45G2217
It is on sale at newegg right now and is an absolutely beautiful case. Just an idea though! Good luck with the build!
Ryzen 9 3950x - 64 GB DDR4 - NVME 980 pro SSD - EVGA RTX 3080 FTW Ultra - FAD CASE
Full custom loop / links below out of date
LTT Build Log | PCPP Build Log
_____________________________________________________________________________________________
Sorry if I stop responding, I've probably gotten busy as I mostly am only on here while working.
https://linustechtips.com/topic/686731-first-build-ever/#findComment-8817203
You don't need a 165Hz monitor for the 2nd screen if you are only using it for editing etc.
Also swap the psu to the G2 version or a Corsair RMx/RMi.
I would also get some faster ram as Skylake can benefit from it.
http://pcpartpicker.com/product/Bgbkcf/corsair-vengeance-lpx-32gb-2-x-16gb-ddr4-3000-memory-cmk32gx4m2b3000c15w
https://linustechtips.com/topic/686731-first-build-ever/#findComment-8817206
Can you edit the psu for me I have no clue what you are talking about sorry
https://linustechtips.com/topic/686731-first-build-ever/#findComment-8817219
Do you mean this? http://pcpartpicker.com/product/9q4NnQ/evga-power-supply-220g20650y1
https://linustechtips.com/topic/686731-first-build-ever/#findComment-8817236
RMx -http://pcpartpicker.com/product/9q38TW/corsair-power-supply-cp9020092na
G2 - http://pcpartpicker.com/product/MfJwrH/evga-power-supply-220g20750xr
RMi - http://pcpartpicker.com/product/C3bkcf/corsair-power-supply-cp9020082na
The RMi is the best out of the three, but obviously a bit more expensive. They all have 10 year warranties.
https://linustechtips.com/topic/686731-first-build-ever/#findComment-8817237
No, not really. More expensive things aren't always better. I'm just sitting here thinking of what to reply to of such an imbecilic response.
  • CPU
    Intel I-7 6700
  • Motherboard
  • RAM
    16 GB Crucial
  • GPU
    Msi 4gb GTX 960
  • Case
    Corsair 380t
  • Storage
  • PSU
  • Display(s)
    Asus VS278
  • Cooling
  • Keyboard
    Logitech G105
  • Sound
  • Operating System
    Windows 10
https://linustechtips.com/topic/686731-first-build-ever/#findComment-8826271
How about something like this ?
Swapped the cpu to the 6 core i7 5820K. You can change it to the i7 6800K if you want the newer Broadwell-E cpu.
If you are only gaming on one of the monitors then you don't need a 165Hz screen for the 2nd one. The Asus PB278Q is a 60Hz 1440p IPS screen which will be fine for doing the video editing on. Then use the Acer 165Hz as the main gaming screen.
The Samsung 950 PRO has much faster read/write speeds than the 850 EVO and has the same 5 year warranty. There is a newer 960 PRO/EVO but they are not on pcpartpicker from what I can see. You also have the SM 961/PM 961 but these have shorter 2 year warranties.
The WD Black has a 5 year warranty and they are more durable than standard drives.
The EVGA G2L is a new psu from EVGA. It has the same 10 year warranty as the G2 750W. If you can't find the G2L then just go with one of the others I listed in my post above.
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($368.99 @ SuperBiiz)
CPU Cooler: CRYORIG A80 128.0 CFM Liquid CPU Cooler  ($105.00 @ Newegg)
Motherboard: Asus X99-A II ATX LGA2011-3 Motherboard  ($223.98 @ Newegg)
Memory: Corsair Vengeance LPX 32GB (4 x 8GB) DDR4-2666 Memory  ($175.99 @ Newegg)
Storage: Samsung 950 PRO 512GB M.2-2280 Solid State Drive  ($314.99 @ Newegg)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive  ($118.99 @ SuperBiiz)
Video Card: Zotac GeForce GTX 1080 8GB AMP! Extreme Video Card  ($664.99 @ B&H)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($95.98 @ Newegg)
Power Supply: EVGA G2L 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($89.99 @ Newegg)
Case Fan: NZXT Air Flow Series 59.1 CFM  120mm Fan  ($9.99 @ Directron)
Monitor: Asus PB278Q 27.0" 60Hz Monitor  ($385.98 @ Newegg)
Monitor: Acer XB271HU bmiprz 27.0" 165Hz Monitor  ($780.98 @ Newegg)
Total: $3355.83
Generated by PCPartPicker 2016-11-08 07:41 EST-0500
https://linustechtips.com/topic/686731-first-build-ever/#findComment-8828114
Total: $3355.83
I know that most games dont use cpu but can I still game with the cpu? Im new to pc gaming.
https://linustechtips.com/topic/686731-first-build-ever/#findComment-8847171
Total: $3355.83
15 minutes ago, lee32uk said:
Yes the i7 5820K (Or i7 6800K) are both fine for gaming with. The extra cpu cores will also help with Video editing.
Okay the 6800k qould that be okay to go with?
https://linustechtips.com/topic/686731-first-build-ever/#findComment-8847412
http://pcpartpicker.com/list/PjpJtJ
So this build and what does it mean BIOS update can I still use this MObo or no?
https://linustechtips.com/topic/686731-first-build-ever/#findComment-8847431
http://pcpartpicker.com/list/rrrhKZ I meant this build Because it has the swift I would like the brands of monitors to match or is the acer one better?
https://linustechtips.com/topic/686731-first-build-ever/#findComment-8847444
It means that some of the 1st gen X99 boards might need a bios update to work with the newer Broadwell-E cpu's. The Asus X99A-II should work fine out of the box with the i7 6800K as it is listed as being compatible with the initial bios release.
https://linustechtips.com/topic/686731-first-build-ever/#findComment-8847474
Okay and what about the monitors is the acer or the asus better?
https://linustechtips.com/topic/686731-first-build-ever/#findComment-8847479
Stick with the Asus ROG Swift as it is cheaper than the Acer. The Asus is a good monitor.
https://linustechtips.com/topic/686731-first-build-ever/#findComment-8847484
And sorry im new to pc gaming and pc in general I use an I Mac as of now to edit but can I over clock that cpu with that mother board
https://linustechtips.com/topic/686731-first-build-ever/#findComment-8847496
Yes you can overclock the cpu.
Okay and this is still a little under my budget is there anything else I should possibly upgrade maybe get a third monitor a maybe use it for my console games or upgrade something else like the case
https://linustechtips.com/topic/686731-first-build-ever/#findComment-8847520
Console gaming is better on a large TV imo :D
The build looks fine to me, so I can't say I would change anything. Do you have a nice Mouse/Keyboard/Headset ?
https://linustechtips.com/topic/686731-first-build-ever/#findComment-8847547
I have a Razer Black Widow X Chroma And A Death Adder Chroma And An Old A40 Headset Im up to replace headphones but keyboard and mouse are new. And i need a extended mouse pad ill be building a custom desk soon
https://linustechtips.com/topic/686731-first-build-ever/#findComment-8847556
