9 minutes ago, Professor Richi said:
Need Cpu,Gaming World of Tanks,light Video editing,800$ budget pc build
what graphics settings do you want to use?
and with some vid editing you might need some threads
i7-7700k @4.8GHz
Asus Maxmius IX hero
EVGA GTX 1080Ti FTW 3
850w EVGA PSU
32GB corsair LPX ddr4 ram
https://linustechtips.com/topic/686637-i-need-help/#findComment-8816136
Hey, could you try follow these guidelines as they help everyone to determine whats best for you :)
1. Budget & Location
You may have listed a heap of parts that all add up to your preferred budget but it is easier if you just list the total amount you'd like to spend and the currency as well as if you'd consider going above that budget for more performance. We need the location as well because $US are different to $AUD and $CAD ect.
2. Aim
What is the system going to be used for? Web browsing, 3D work? Different systems need different levels of performance - a computer based for web browsing and office use won't handle heavy graphic design and video editing and a proper video editing system isn't good for gaming. If your aim is for gaming, please list what sort of gaming. In the same way that different usage types need different systems, you'll need a lot more power to run Far Cry 3 or Crysis 2 than you would Minecraft.
3. Monitors
How many monitors do you plan on running? Do you plan on moving to more monitors in the future? What resolution are they at too?
4. Peripherals
Do you also need to purchase peripherals such as keyboards and mice as well as monitors ect. Also please tell us if you'll need an OS such as Windows.
5. Why are you upgrading?
We ask this because you may see upgrading as the only path to solve an issue but things such as driver updates, reconfiguration or cleaning can boost performance without spending a cent.
Please copy and paste the major dot points into your thread as it makes it easier for us to give you better feedback.
Have fun and keep building :)
https://linustechtips.com/topic/686637-i-need-help/#findComment-8816194
PCPartPicker part list: http://pcpartpicker.com/list/vmLDJV
Price breakdown by merchant: http://pcpartpicker.com/list/vmLDJV/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($194.89 @ OutletPC)
Motherboard: Gigabyte GA-B150M-DS3H Micro ATX LGA1151 Motherboard  ($52.98 @ Newegg)
Memory: Crucial Ballistix Sport LT 16GB (2 x 8GB) DDR4-2400 Memory  ($89.99 @ B&H)
Storage: Sandisk Z400s 128GB 2.5" Solid State Drive  ($43.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($47.33 @ OutletPC)
Video Card: Asus GeForce GTX 1060 6GB 6GB Dual Video Card  ($269.99 @ B&H)
Case: Deepcool DUKASE WHV2 ATX Mid Tower Case  ($54.99 @ Newegg)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.99 @ Newegg)
Total: $804.15
Generated by PCPartPicker 2016-11-06 06:12 EST-0500
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/686637-i-need-help/#findComment-8816275
2. Aim
3. Monitors
4. Peripherals
 1.Budget and Location
I'm Currently living in Malaysia but my budget is in USD
2.Aim
Im Currently training for reports,doing YouTube (Which involves video editing)
And Streaming on twitch
3.Monitors
Just 1 1920X1080 Monitor right now at home and I am planning to upgrade to 2560X1440 at some time later
4.Peripherals
I am needing a new headset, microphone (Cheap but like blue yeti) webcam, mouse and keyboard, and gonna need a fresh install of windows 10 (All of these are not included in the budget)
5.Why I'm upgrading
This is because my old system feels sluggish and can't game or video edit at all.
Specs:I5-4460,
4 GB DDR-3 (2.9 GB Usable)1600MHZ,
1 TB Seagate Barracuda Hardrive (926 GB Usable)
https://linustechtips.com/topic/686637-i-need-help/#findComment-8822803
2.Aim
3.Monitors
4.Peripherals
5.Why I'm upgrading
Specs:I5-4460,
Any type of streaming or encoding while gaming is going to crush an i5, speaking from personal experience. Assuming your not running the most intensive games and cutting the budget back some on a gpu to get the i7 for going to want for editing and streaming I would recommend a build along these lines . http://pcpartpicker.com/list/3th7vV
https://linustechtips.com/topic/686637-i-need-help/#findComment-8826141
