I started a thread a couple of days ago you can see here.
However, since I've got the idea and have been looking all over the interwebs at cases, I've come into a dilemma. I can't decide which case would look best for this idea.
I initially went with the Noctis 450. After some more research, I then thought maybe the Corsair Spec Alpha was a better choice. But now I'm looking at the Cooler Master Case Pro 5. The modularity and angular design would offer plenty of customizable options.
Which of the 3 do you guys think would be best? I'm sort of leaning away from the Noctis personally, but haven't ruled it out completely. Are there any other cases you think would work as well?
Also, I'm pretty sure the motherboard and gpu are set in stone but it never hurts to ask the community. Are there any other components you think would look better with this build?
https://linustechtips.com/topic/686179-master-chief-case-mod-debate/
