Need help MSI laptop
Go to solution Solved by U.Ho,
1 minute ago, El Poncho said:
I get a yellow triangle next to it in device manager now and an error code 10
If you're using windows 10, I suggest to uninstall the driver altogether and reboot. See if a driver gets installed automatically and if it's any better then.
How does the issue present itself?
Error messages?
Taskbar icon showing up as red cross or yellow triangle?
Have you tried the newest drivers?
How about one or two versions older drivers?
Do you have a working wifi connection with another adapter so we can rule out the wifi being bad?
https://linustechtips.com/topic/686092-need-help-msi-laptop/#findComment-8811218
Error messages?
In the start there wasa yellow triangle in the device manager but now it just disappears from the task msnager it also shows a red cross till the wifi symbol just disappears in the bottom left.
i have tried the newest havent tried older but i might try it in a bit.
yes my phone is connected to the same internet and so is my dad and grandmothers laptops.
https://linustechtips.com/topic/686092-need-help-msi-laptop/#findComment-8811231
How does it look in device manager (control panel --> system --> device manager --> network adapters) or network adapter settings (control panel --> network and sharing center --> change adapter settings)?
https://linustechtips.com/topic/686092-need-help-msi-laptop/#findComment-8811239
The network adapter doesnt show up in the list and now i get a yellow triangle
https://linustechtips.com/topic/686092-need-help-msi-laptop/#findComment-8811337
Ok, that shouldn't happen.
Do you have something else connected? A cable?
If you don't have the adapter in the list, you can not get a yellow triangle. You pretty much can't get anything, except red cross.
(Yellow triangle means there's something wrong with the connection but there is a connection. Red cross means there's no connection which should be the case if there's no adapter at all)
https://linustechtips.com/topic/686092-need-help-msi-laptop/#findComment-8811346
https://linustechtips.com/topic/686092-need-help-msi-laptop/#findComment-8811349
If you have a secondary Harddrive laying i would suggest doing a fresh install on that to eliminate a Windows issue.
CPU: 2x E5620 - GPU: 2x GTX660 - RAM: 64gb DDR3 ECC - Mobo: Z800 OEM - Storage:1TB WD Green - 256gb - Micron C400 250gb - 850 EVO - 512gb 850 PRO
Monitors: 3x HP ZR2440W - Keyboard: G710 MX Blue - Mouse: MX Master
Keep up the good tone and stay classyxD
https://linustechtips.com/topic/686092-need-help-msi-laptop/#findComment-8811351
https://linustechtips.com/topic/686092-need-help-msi-laptop/#findComment-8811352
Totally agree with @U.Ho
If that does not work then try a fresh install or running of a live Ubuntu USB. That could potentially rule out hardware issues
https://linustechtips.com/topic/686092-need-help-msi-laptop/#findComment-8811355
Do you think it would be better to install a driver from intels website? (Ill try what you said)
https://linustechtips.com/topic/686092-need-help-msi-laptop/#findComment-8811455
