Intervalometer Vs. Remote Shutter release
Go to solution Solved by AkiraDaarkst,
1 hour ago, cc143 said:
I am looking to get an Intervalometer and Remote Shutter release for my camera, and was wandering whether the intervalometer could double as both, so I don't need to get a separate shutter release.
This is what I have come up with till now: https://www.amazon.co.uk/VILTROX-MC-C3-Intervalometer-Control-Shutter/dp/B0158HHKC0/ref=sr_1_2?ie=UTF8&qid=1478266956&sr=8-2&keywords=eos+50d+intervalometer
there are cheaper ones out there, but I have got viltrox accessories and would prefer going with them over another brand I don't really know.
Can I use this as a remote shutter release as well, or should I be looking at getting a seperate one?
You should be able to use it as a shutter release.  The big button in the middle is the manual shutter release button.  An intervalometer is just an elaborate shutter release that has a timing device that also closes the circuit which triggers the shutter.
6700k|Hyper 212 EVO|Asus Z170 Deluxe|GTX970 STRIX|16gb 2400mhz Teamgroup memory|Samsung 950 PRO+ 2TB Seagate HDD| CM Realpower M1000|H440
Take a look at my flickr?:  https://www.flickr.com/photos/150012948@N06/
https://linustechtips.com/topic/685724-intervalometer-vs-remote-shutter-release/
That is not dead which can eternal lie.  And with strange aeons even death may die. - The Call of Cthulhu
A university is not a "safe space". If you need a safe space, leave, go home, hug your teddy & suck your thumb until ready for university.  - Richard Dawkins
