5 minutes ago, ripper101 said:
So I am looking for a VESA mount that will attach to the wall and will hold 2 23" monitors and isn't very expensive.
i want the monitors to be able to position like this
What size is the vesa mount? Is it 75 or 100mm?
https://linustechtips.com/topic/685386-need-a-vesa-mount/#findComment-8803389
2 minutes ago, CapedCrusader21 said:
This is a $80 75 or 100mm vesa mount that has pretty good reviews if you are interested.
It holds 2 monitors BTY.
http://www.monoprice.com/product?c_id=109&cp_id=10828&cs_id=1082808&p_id=13815&seq=1&format=2
https://www.amazon.com/Adapter-Bracket-i2367Fh-i2757Fh-i2267Fw/dp/B01A3XDIQQ
this is the adapter I need if it tells you the size
https://linustechtips.com/topic/685386-need-a-vesa-mount/#findComment-8803435
