33 minutes ago, Zaydoon said:
Anyone knows how to put the transformer part outside the case and the output inside the case, anyone makes these .thanks
You could theoretically have the actuall psu outside the case and the wires go inn through the back, but this won't exactly look good. Why do you want to do this?
“When life gives you lemons, don’t make lemonade. Make life take the lemons back! Get mad! I don’t want your damn lemons, what the hell am I supposed to do with these? Demand to see life’s manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I’m the man who’s gonna burn your house down! With the lemons! I’m gonna get my engineers to invent a combustible lemon that burns your house down!”
- Cave Johnson, founder and CEO of Aperture Science, in Portal 2
https://linustechtips.com/topic/685181-external-power-supply/#findComment-8801095
The transformer is physically a part of the power supply on the pcb inside, you can't just rip it out.
There are motherboards that run off of a laptop charging bricks, or you could get psu extensions and mover the entire psu out of the case.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/685181-external-power-supply/#findComment-8801112
Well I assume by transformer you mean the whole PSU (as in the older terminology of referring to any PSU as a transformer). Otherwise as @SLAYR said, the "transformer" is a component that is soldered on to the board of the PSU.
You could just get all of the wires, put them in a tube of some sort (or ziptie them together), and have all of the wires go into the case. Some non-modular PSU's sorta do this already (at least for the first few inches) since all of the wires come out of one hole. You can use extensions if the cables aren't long enough.
May Our Framerates Be High And Our Temperatures Be Low.
PSUs: EVGA B2/G2/GQ/GS, Corsair RMx/i, Grey-Label CXM, Everything Seasonic/Delta/Super Flower, XFX except XT
Use pcpartpicker.com
https://linustechtips.com/topic/685181-external-power-supply/#findComment-8804303
1 hour ago, Zaydoon said:
I just want to take advantage of consol sized cases.
SFX or TFX power supply is what most of them take.
https://linustechtips.com/topic/685181-external-power-supply/#findComment-8804324
