Hi!
When I record my microphone on my PC, there is a loud buzz/static noise. When I tried the microphone on my laptop with the same settings, that static noise was gone.
My friend said that my cheap PSU could be the problem, so should I buy a new one?
PC Specs:
PSU: Corsair VS650
Mobo: ASRock P67 pro3
Graphics: Evga GTX 580
Microphone: Superlux 205U
https://linustechtips.com/topic/685173-usb-microphone-static/
5 minutes ago, perunatarha said:
Hi!
PC Specs:
PSU: Corsair VS650
have you tried a different cable from you microphone to your pc and tried a different usb port?
https://linustechtips.com/topic/685173-usb-microphone-static/#findComment-8800948
If you have your laptop charging, will there be a buzzing noise? It might be a ground loop issue of some sort.
Is your pc connected into a grounded outlet?
If you live in a old house, the ground might also be connected to neutral instead of earth, and that might cause problems as well.
Oh, your psu is craptastic. If you can, try with a better psu. Bad capasitors might induce ripple which causes all kinds of problems.
http://www.tomshardware.co.uk/answers/id-1855407/corsair-series-psu-quality.html
https://linustechtips.com/topic/685173-usb-microphone-static/#findComment-8801086
PC is connected to a outlet without a ground. Laptop was charging in the same outlet and the buzz was gone.
I guess I will just try a new PSU then. Thanks!
https://linustechtips.com/topic/685173-usb-microphone-static/#findComment-8801119
