Help! Android java keeps crashing
Go to solution Solved by Sergio45,
package com.ebookfrenzy.secretshoppers;
import android.graphics.Color;
import android.os.Bundle;
import android.support.v7.app.AppCompatActivity;
import android.view.View;
import android.widget.AdapterView;
import android.widget.Button;
import android.widget.CheckBox;
import android.widget.CompoundButton;
import android.widget.EditText;
import android.widget.RadioButton;
import android.widget.RadioGroup;
import android.widget.Spinner;
import android.widget.Toast;
public class SecretShoppers extends AppCompatActivity
   // private static final String THE_NAME="THE_NAME";
//    private static final String THE_COMMENTS="THE COMMENTS";
  //  private static final String THE_SCORE="THE_SCORE";
    private double scoreBeforeSubmit;//the score if the user has not
    //pressed the submit button to get the score.
    //private double currentScore;//the score that is currently being counted.
  //  private double finalScore;//the end score
    EditText establishmentName;//name of the place
    EditText commentBoxText;//the comments the user enters
    EditText currentScore;//the current score
    private int [] checklistValues = new int [21];//19 values
    //for the check boxes and , radio, spinner
    CheckBox happyCheckBox;//happy_checkBox
    CheckBox fairCheckbox;//fair_checkBox
    CheckBox annoyedCheckbox;//annoyed_checkBox
    CheckBox veryCheckbox;//very_CheckBox
    CheckBox notveryCheckBox;//not_CheckBox
    CheckBox neededhelpCheckBox;//needed_help_CheckBox
    RadioGroup HelpRadioGroup;//employeeHelpRadioGroup
    RadioButton yesRadioButton;//yes_radioButton
    RadioButton noRadioButton;//no_radioButton
    RadioButton askRadioButtonl;//ask_RadioButton;
    Spinner ratingScaleSpinner;
    Button submitButton;//submitButton
    Button clearButton;//clearButton
    private String Textbox;
    private String TextboxTwo;
    private String colorChangerText;
    @Override
    protected void onCreate(Bundle savedInstanceState)
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_secret_shoppers);
        if(savedInstanceState == null)
            //just started
            scoreBeforeSubmit=0;
           // currentScore = 0;
        else
            //app is being restored
           // scoreBeforeSubmit=savedInstanceState.getDouble(THE_SCORE);
            //currentScore=savedInstanceState.getDouble(THE_SCORE);
        //initialize the edit texts
        establishmentName = (EditText) findViewById(R.id.nameEstablishmentEditText);
        commentBoxText = (EditText)findViewById(R.id.commentEditText);
        currentScore = (EditText)findViewById(R.id.currentScoreEditText);
        //initialize the seekbar and add a change listener
        happyCheckBox=(CheckBox)findViewById(R.id.happyCheckBox);//happy_checkBox
        fairCheckbox=(CheckBox)findViewById(R.id.fairCheckBox);//fair_checkBox
        annoyedCheckbox=(CheckBox)findViewById(R.id.annoyedCheckBox);//annoyed_checkBox
        veryCheckbox=(CheckBox)findViewById(R.id.veryCheckBox);//very_CheckBox
        notveryCheckBox=(CheckBox)findViewById(R.id.notCheckBox);//not_CheckBox
        neededhelpCheckBox=(CheckBox)findViewById(R.id.neededHelpCheckBox);//needed_help_CheckBox
        setUpEmployeeAttiude();
        setupKnowledge();
        yesRadioButton = (RadioButton)findViewById(R.id.yesRadioButton);//yes_radioButton
        noRadioButton= (RadioButton)findViewById(R.id.noRadioButton);//no_radioButton
        askRadioButtonl= (RadioButton)findViewById(R.id.askRadioButton);//ask_RadioButton;
       HelpRadioGroup = (RadioGroup) findViewById(R.id.employeeHelpRadioGroup);
        addChangeListenerToRadios();
        ratingScaleSpinner=(Spinner)findViewById(R.id.ratingScaleSpinner);
        ratingScaleSpinner.setPrompt("First Impression Rating");
       addItemSelectedListenerToSpinner();
        submitButton = (Button)findViewById(R.id.submitButton);
        clearButton = (Button)findViewById(R.id.clearButton);
        setupButtonOnClickListeners();
        setTipFromWaitressChecklist();
    private void setUpEmployeeAttiude()
        happyCheckBox.setOnCheckedChangeListener(new CheckBox.OnCheckedChangeListener()
            @Override
            public void onCheckedChanged(CompoundButton buttonView, boolean isChecked)
                checklistValues[0] = (happyCheckBox.isChecked())?60:0;
        fairCheckbox.setOnCheckedChangeListener(new CheckBox.OnCheckedChangeListener()
            @Override
                checklistValues[1]= (fairCheckbox.isChecked())?0:0;
                //updateFinalScore();
        annoyedCheckbox.setOnCheckedChangeListener(new CheckBox.OnCheckedChangeListener()
            @Override
                checklistValues[2]= (annoyedCheckbox.isChecked())?-10:0;
    private void setupKnowledge()
        veryCheckbox.setOnCheckedChangeListener(new CheckBox.OnCheckedChangeListener()
            @Override
                checklistValues[3] = (veryCheckbox.isChecked())?20:0;
        notveryCheckBox.setOnCheckedChangeListener(new CheckBox.OnCheckedChangeListener()
            @Override
                checklistValues[4] = (notveryCheckBox.isChecked())?-10:0;
        neededhelpCheckBox.setOnCheckedChangeListener(new CheckBox.OnCheckedChangeListener()
            @Override
                checklistValues[5] = (neededhelpCheckBox.isChecked())?-10:0;
    private void setTipFromWaitressChecklist()
        int checklistTotal = 0;
        // Cycle through all the checklist values to calculate
        // a total amount based on waitress performance
        for(int item : checklistValues)
            checklistTotal += item;
        // Set tipAmountET
        currentScore.setText(new String(String.valueOf(checklistTotal)));
    private void addChangeListenerToRadios()//yesRadioButton noRadioButton askRadioButtonl
        HelpRadioGroup.setOnCheckedChangeListener(new RadioGroup.OnCheckedChangeListener()
            @Override
            public void onCheckedChanged(RadioGroup group, int checkedId)
                checklistValues[6]=(yesRadioButton.isChecked())?10:0;
                checklistValues[7]=(noRadioButton.isChecked())?-40:0;
                checklistValues[8]=(askRadioButtonl.isChecked())?-50:0;
    private void  addItemSelectedListenerToSpinner()
        ratingScaleSpinner.setOnItemSelectedListener(new AdapterView.OnItemSelectedListener()
            @Override
            public void onItemSelected(AdapterView<?> parent, View view, int position, long id)
                checklistValues[9]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("10"))?10:0;
                checklistValues[10]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("9"))?9:0;
                checklistValues[11]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("8"))?8:0;
                checklistValues[12]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("7"))?7:0;
                checklistValues[13]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("6"))?6:0;
                checklistValues[14]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("5"))?5:0;
                checklistValues[15]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("4"))?4:0;
                checklistValues[16]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("3"))?3:0;
                checklistValues[17]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("2"))?2:0;
                checklistValues[18]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("1"))?1:0;
                checklistValues[19]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("0"))?-1:0;
            @Override
            public void onNothingSelected(AdapterView<?> parent)
    public void getTheName()
      String name=String.valueOf(establishmentName.getText());
      String addon=" Got the Score of"+" "+currentScore.getText();
        TextboxTwo = establishmentName.getText().toString();
        String empty="Please don't forget to enter a name";
        if (TextboxTwo.matches(""))
            Toast.makeText(this,empty,Toast.LENGTH_LONG).show();
        else
            Toast.makeText(this,name+addon,Toast.LENGTH_LONG).show();
            currentScore.setTextColor(Color.parseColor("#f44242"));
    public void getTheComments()
        Textbox = commentBoxText.getText().toString();
        String empty="Please don't forget to enter some comments.";
        String comments = "Thanks for the comment(s), we will keep them in our records";
        if (Textbox.matches(""))
        else
            Toast.makeText(this, comments, Toast.LENGTH_LONG).show();
            commentBoxText.setText("");
   private void setupButtonOnClickListeners()
        submitButton.setOnClickListener(new View.OnClickListener()
            @Override
            public void onClick(View v)
             getTheName();
                getTheComments();
                       //currentScore.setText(new String(String.valueOf(checklistTotal)));
        clearButton.setOnClickListener(new View.OnClickListener()
            @Override
                establishmentName.setText("");
                currentScore.setText("");
I am just building the methods for the me to work on the project later this week. I started adding EventListeners and now the emulator won't run the code. Its keep crashing. I was wondering if it was something if its possible to see the error if I post the java file code here?
Thanks in advanced guys and girls.
package com.ebookfrenzy.secretshopper;
public class SecretShopperActivity extends AppCompatActivity {
    //the sume of all radio buttons and check boxes.
    private int[]checklistValues=new int[15];//100 is the max points you can get.
    //Declare the checkboxes.
    CheckBox annoyedCheckBox;
    CheckBox fairCheckBox;
    //Declare the RadioButtons
    RadioGroup yesNoRadioGroupBox;
    RadioButton askRadioButton;
    //Declare the spinner
    //Declare the Buttons
    Button clearButton;
    Button exitButton;
    //EditText for the Results and Name
    EditText FinalscoreEditTextView;
    EditText CurrentscoreEditTextView;
    EditText nameEstablishmentEditTextView;
    //name of the establishment
    private static final String NAME_ESTABLISHMENT="NAME_ESTABLISHMENT";
    private static final String Final_Score="FINAL_SCORES";
    private static final String Current_Score="CURRENT_SCORES";
    private double scoreCurrentRating;//the score before the user adds ratings
    private double scoreFinalRating;//the score for FINAL SCORE.
    @Override
        setContentView(R.layout.activity_secret_shopper);
        //check if the app has started, or if its being restored
            //just started
            scoreCurrentRating=0;
            scoreFinalRating=0;
        else
            scoreCurrentRating=savedInstanceState.getDouble(Current_Score);
            scoreFinalRating=savedInstanceState.getDouble(Final_Score);
        FinalscoreEditTextView = (EditText)findViewById(R.id.finalScoreEditText);
        CurrentscoreEditTextView = (EditText)findViewById(R.id.currentScoreEditText);
        nameEstablishmentEditTextView = (EditText)findViewById(R.id.nameEstablishmentEditTextView);
        //change listener for edit text views
        happyCheckBox = (CheckBox) findViewById(R.id.happyCheckBox);
        annoyedCheckBox= (CheckBox) findViewById(R.id.annoyedCheckBox);
        fairCheckBox= (CheckBox) findViewById(R.id.fairCheckBox);
        //change listener for check boxes
        setUpCheckBoxes();
        yesRadioButton=(RadioButton)findViewById(R.id.yesRadioButton);
        noRadioButton = (RadioButton)findViewById(R.id.noRadioButton);
        askRadioButton = (RadioButton)findViewById(R.id.iAskedRadioButton);
        //change listener for cradio buttons
        yesNoRadioGroupBox=(RadioGroup)findViewById(R.id.yesNoRadioGroupBox);
        ratingScaleSpinner = (Spinner)findViewById(R.id.ratingScaleSpinner);
        ratingScaleSpinner.setPrompt("Rateing Scale");
        clearButton = (Button) findViewById(R.id.clearButton);
        exitButton = (Button) findViewById(R.id.exitButton);
        setButtonOnClickListeners();
    private void setUpCheckBoxes()
            @Override
                checklistValues[0]= (happyCheckBox.isChecked())?10:0;
                //setup the current score
                //currentScoreCheckList();
        annoyedCheckBox.setOnCheckedChangeListener(new CheckBox.OnCheckedChangeListener()
            @Override
                checklistValues[1] = (annoyedCheckBox.isChecked())?1:0;
        fairCheckBox.setOnCheckedChangeListener(new CheckBox.OnCheckedChangeListener()
            @Override
                checklistValues[2]= (fairCheckBox.isChecked())?2:0;
    }//might end wrong here
        yesNoRadioGroupBox.setOnCheckedChangeListener(new RadioGroup.OnCheckedChangeListener()
            @Override
                checklistValues[3]=(yesRadioButton.isChecked())?10:0;
                checklistValues[4]=(noRadioButton.isChecked())?0:0;
                checklistValues[5]=(askRadioButton.isChecked())?-1:0;
                //Setup Current score
                //setup final score
            @Override
                checklistValues[6]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("10 Best"))?10:0;
                checklistValues[7]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("9"))?9:0;
                checklistValues[8]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("8"))?8:0;
                checklistValues[9]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("7"))?7:0;
                checklistValues[10]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("6"))?6:0;
                checklistValues[11]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("5"))?5:0;
                checklistValues[12]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("4"))?4:0;
                checklistValues[13]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("3"))?3:0;
                checklistValues[14]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("2"))?2:0;
                checklistValues[15]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("1 Horrible"))?-1:0;
                //setup the final score
            @Override
    private void setButtonOnClickListeners()
            @Override
                //set up the final score here
                //display it to the final score edit text
                //use the current score and change current score text
                //to blank
            @Override
                //erase the edittextviews of Current and Final
                //uncheck the boxes and radio and spinner
                //erase the name
                //focus back on the name
                //set the score back to zero
        exitButton.setOnClickListener(new View.OnClickListener()
            @Override
                //finish();
                //System.exit(0);
https://linustechtips.com/topic/684911-help-android-java-keeps-crashing/
I might have to do this one slow. I the logcat can not catch anything because it dosen't even run. I did find this :
FATAL EXCEPTION: main
        Process: com.ebookfrenzy.secretshopper, PID: 9298
        java.lang.RuntimeException: Unable to start activity ComponentInfo{com.ebookfrenzy.secretshopper/com.ebookfrenzy.secretshopper.SecretShopperActivity}: java.lang.NullPointerException: Attempt to invoke virtual method 'void android.widget.RadioGroup.setOnCheckedChangeListener(android.widget.RadioGroup$OnCheckedChangeListener)' on a null object reference
        at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2325)
        at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2387)
        at android.app.ActivityThread.access$800(ActivityThread.java:151)
        at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1303)
        at android.os.Handler.dispatchMessage(Handler.java:102)
        at android.os.Looper.loop(Looper.java:135)
        at android.app.ActivityThread.main(ActivityThread.java:5254)
        at java.lang.reflect.Method.invoke(Native Method)
        at java.lang.reflect.Method.invoke(Method.java:372)
        at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:903)
        at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:698)
        Caused by: java.lang.NullPointerException: Attempt to invoke virtual method 'void android.widget.RadioGroup.setOnCheckedChangeListener(android.widget.RadioGroup$OnCheckedChangeListener)' on a null object reference
        at com.ebookfrenzy.secretshopper.SecretShopperActivity.addChangeListenerToRadios(SecretShopperActivity.java:178)
        at com.ebookfrenzy.secretshopper.SecretShopperActivity.onCreate(SecretShopperActivity.java:101)
        at android.app.Activity.performCreate(Activity.java:5990)
        at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1106)
        at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2278)
11-02 17:13:08.091 1497-2225/system_process W/ActivityManager:   Force finishing activity 1 com.ebookfrenzy.secretshopper/.SecretShopperActivity
11-02 17:13:08.303 1123-1123/? E/EGL_emulation: tid 1123: eglCreateSyncKHR(1299): error 0x3004 (EGL_BAD_ATTRIBUTE)
______________________________________
I will go into this and start fixing the cause by errors.
I did change the array to 14.
Edited by Sergio45
FAT FINGERS
Your yesNoRadioGroupBox inside addChangeListenerToRadios() seems to be null, and it is because you first call addChangeListenerToRadios and then you assign radiogroup do variable here:
Ok. So what was causing the error was the array for the checklistValues under the method. I have commented them out and let you guys know what I find with the log cat.
41 minutes ago, Sergio45 said:
private void addItemSelectedListenerToSpinner() { ratingScaleSpinner.setOnItemSelectedListener(new AdapterView.OnItemSelectedListener() { @Override public void onItemSelected(AdapterView<?> parent, View view, int position, long id) { checklistValues[6]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("10 Best"))?10:0; checklistValues[7]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("9"))?9:0; checklistValues[8]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("8"))?8:0; checklistValues[9]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("7"))?7:0; checklistValues[10]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("6"))?6:0; checklistValues[11]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("5"))?5:0; checklistValues[12]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("4"))?4:0; checklistValues[13]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("3"))?3:0; checklistValues[14]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("2"))?2:0; checklistValues[15]=(String.valueOf(ratingScaleSpinner.getSelectedItem()).equals("1 Horrible"))?-1:0; //setup the current score //setup the final score } @Override public void onNothingSelected(AdapterView<?> parent) { } }); }
I see and when I did comment that back in also it did crash the application. hmmmm. let me see if I can change that .
I move the addChange and addItem call methods to the submit button. From there I am going to see if I can get LogCat going.
 private void setButtonOnClickListeners() {
        submitButton.setOnClickListener(new View.OnClickListener() {
            @Override
            public void onClick(View v) {
                //to blank
I got the code working, I had a method that was expecting a Edit-text  to be initialize with something in the beginning. I found the error by re-building the application and adding on to it. I was actually pretty glad that it crashed because it gave me the opportunity to re-think my approach on the code. I will post the java portion of the code when I get home.it's almost done just have to clean it up a bit. I just added more check boxes .
    @Override
            //just started
        else
        setupKnowledge();
            @Override
            @Override
            @Override
            @Override
            @Override
            @Override
        // Set tipAmountET
            @Override
            @Override
            @Override
        else
        else
            @Override
             getTheName();
                getTheComments();
            @Override
