Hey fellas I'm planning on upgrading the rig real soon and I was wondering if my current PSU will have enough juice to run/ possibly OC my new rig. This is what I'll be working with
CPU: Intel Core i7-6700K 8M Skylake Quad-Core 4.0 GHz LGA 1151 91W looking for slight OC
Cpu cooler: Hyper 212 LED with PWM Fan, Four Direct Contact Heatpipes, Unique Fan Blade Design, Red LEDs, Optimized Bracket Design by Cooler Master http://www.newegg.com/Product/Product.aspx?Item=35-103-218
Ram: G.SKILL Ripjaws V Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3000 (PC4 24000)  hoping to OC
HDD: Seagate Constellation ES.3 ST1000NM0033 1TB 7200 RPM 128MB Cache SATA 6.0Gb/s 3.5" Enterprise
ssd: Samsung eco 850 240gb
graphics card: zotac gtx 1070 amp extreme OC'd
PSU:SeaSonic G Series SSR-550RM 550W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS GOLD Certified
thanks in advance everyone!
https://linustechtips.com/topic/684873-psu-help/
It's more than enough.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/684873-psu-help/#findComment-8797730
Personally, I would say you'll be fine.
Check out this PSU calculator. I quickly entered some of your system details.
http://outervision.com/b/ixgKzv
https://linustechtips.com/topic/684873-psu-help/#findComment-8797733
If you are having trouble with keeping track of all of your parts, I highly recommend using:
 https://ca.pcpartpicker.com/
It helps you keep track of prices, power consumption, and various other compatibility issues.
Current Build ~ "白龍"
CPU: Intel Core i5-4690K     Mobo: Asus Z97-A     Ram: Corsair Vengeance 8GB DDR3-1600Mhz (2x4GB)     HDD:  WD Caviar Blue 1TB     SSD: Samsung 850 EVO 250GB     GPU: MSI GTX 970 4GB Twin Frozr V      Case: NZXT Noctis 450     PSU: Corsair CX 600W     Mouse: Corsair M60     Keyboard: Logitech G710+ (MX Brown)     IEM: ATH-IM04
https://linustechtips.com/topic/684873-psu-help/#findComment-8797761
You should be fine.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/684873-psu-help/#findComment-8797788
Seasonic Gs are really good but they're a bit noisy.
If you can get a M12II EVO for a bit less, that on's bronze but it's fully modular and still great, and not as loud.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/684873-psu-help/#findComment-8797796
I don't think he wants to get a new PSU because of noise. Just wants to get a new one if he needs more watts/power/juice.
https://linustechtips.com/topic/684873-psu-help/#findComment-8797803
Either way the G is really good
Computer Specs:
https://linustechtips.com/topic/684873-psu-help/#findComment-8797806
