Well got mad of the lag and hit the box windows 10 pop out and said thats found a problem then I shutdown it open it looked some cables and switchEd the ram and yea still didn't post just runs with the fans and black screen. If someone can help me i will appreciate it thanks.
well make ur dreams come true
https://linustechtips.com/topic/682292-pc-wont-post/
Reset cmos
Main system:
i7 6700k @4.8ghz 1.45v
ROG Maximus Hero VIII
Gigabyte G1 980ti Sli @1500 ghz
Samsung 950 pro 512gb
16gb G.Skill Ripjawz V @3400mhz
Corsair H115i 280mm AIO
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Intel i3 6100 @4.6ghz 1.52v
Asrock B150M Pro4/Hyper
Intel 750 series 400gb
Radeon Rx 470 XFX
Thermaltake Water 3.0 360mm AIO
inWin 303 case
AMD Phenom II x4 940 @3.9ghz 1.65v
Gigabyte 780g mobo
Corsair H100 240mm AIO
Corsair Dominiator 8gb DDR2 @1066
Evga GTX 750ti FTW @1450mhz
Thermaltake Matrix case (modded)
"The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage"
https://linustechtips.com/topic/682292-pc-wont-post/#findComment-8771734
Take out gpu and try post with igpu
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
https://linustechtips.com/topic/682292-pc-wont-post/#findComment-8771835
Does your pc have a video card?
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
https://linustechtips.com/topic/682292-pc-wont-post/#findComment-8771854
Just now, vramnik7 said:
Yep
Remove it and try using the onboard graphics via motherboard  assuming your cpu has intergrated graphics support. Can you list all your components too will help thanks
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
https://linustechtips.com/topic/682292-pc-wont-post/#findComment-8771871
1 minute ago, vramnik7 said:
Damn 6 years 775 old ass :(
A you running a GPU in it? or integrated off the Mobo? Either way could be motherboard failure. That's the same situation I encountered with mine. Random freezes, Windows bluescreens, ECT. Turned out to just be a bad old OEM motherboard.
i7-6700k OC'd 4.5Ghz, Noctua NH-D15, EVGA GEFORCE GTX 1070 SC
https://linustechtips.com/topic/682292-pc-wont-post/#findComment-8771873
Yes hd 7770 sapphire
https://linustechtips.com/topic/682292-pc-wont-post/#findComment-8771884
Ok pretty sure that has igpu. Try removing the hd7700 just to confirm its not the video card. Not likly but better to find out if it is or isnt. Can you get to the bios at all? Have you spamed f2 or del on boot? If you can get a display its most likly the hdd has either broke or is corrupted.
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
https://linustechtips.com/topic/682292-pc-wont-post/#findComment-8771899
Well my hdd is thrash so yea can't post noo beep and yea
https://linustechtips.com/topic/682292-pc-wont-post/#findComment-8771917
So cannot get to bios?
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
https://linustechtips.com/topic/682292-pc-wont-post/#findComment-8771923
If it was only your hdd you should still be able to get a display of some sort. If the igpu hasnt worked and you cannot get a bios display, and ram swapping and clearing cmos hasnt worked. Theres a chance the knock has damaged the motherboard or even the cpu itself.
May be time for a new pc ?
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
https://linustechtips.com/topic/682292-pc-wont-post/#findComment-8771962
3 minutes ago, vramnik7 said:
Did it thanks
Alright, what fixed it?
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
https://linustechtips.com/topic/682292-pc-wont-post/#findComment-8771965
well just switched some cables for hdd but i turned it windows now is like 2x times slower opening stuff and yea i know i need new pc i have 1 awesome build for 2k $ but dont have cash i am broke and yea :(
https://linustechtips.com/topic/682292-pc-wont-post/#findComment-8772079
Well thats good. You dont need to spent 2k to get a good pc. Glad you got it working though man ?
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
https://linustechtips.com/topic/682292-pc-wont-post/#findComment-8772269
